Moonroof Rattle
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by garyyamane, Feb 16, 2014.
  1. garyyamane
    garyyamane Junior Member
    50
    Taos, NM
    Anyone experiencing a rattle from the moonroof area when on slightly rough roads or any other time? If so what did you do?
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I hear it coming from the right side. If I hit the roof enough it will stop for a bit. It is quite annoying.
  3. garyyamane
    50
    Taos, NM
    I've tried opening/closing, vent open/closed, shade open/closed, ran my fingers around the edges, and nothing seems to stop it and can't really tell what is causing it.
  4. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I'm not sure either. It's been that way since day one. But I'm not taking it all apart to find it. I can live with it. If it gets any worse then maybe one day I will take it in...
  5. I've never opened the sunroof (except for the shade part, which I usually just keep except on hot days), but I've never heard any rattle from it. My morning commute is through craters in the road and the only thing that rattles is the whole car from the bumps.
    Not sure why there is a rattle. When it rains, or when you take it to a car wash, does it leak?
  6. bisco
    49,494
    when our hycam moonroof rattled, we took it in and they had a repair/update kit for it, no charge.
  7. garyyamane
    50
    Taos, NM
    The moonroof does not leak.
    Nexus 7 ?
  8. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Nope no leaks.
