More Details on Active Grille Shutters (Video)
Discussion in 'Gen 4 Prius Technical Discussion' started by Tideland Prius, Oct 26, 2017.
  1. Tideland Prius
    16,615
    Toyota Canada video on active grille shutters. Learned something new (e.g. winter control mode)
  2. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Excellent find! Thanks!
    Tideland Prius likes this.
  3. Prodigyplace
    12,670
    11,828
    Central Virginia
    Winter mode is interesting.
    Thanks for sharing.
    Tideland Prius and KV55 like this.
  4. KV55
    KV55 Member
    126
    43
    Northamptonshire, UK
    Excel
    Could be a job for the ScanGauge; open when above 40C but at speeds lower than 60kph might not be so good for engine heat loss during pulse and glide in cool weather. Has anyone blocked the upper vent yet?
  5. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    Don’t the boffins at Toyota know what they’re doing?
    iPhone ?
  6. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    Slightly disappointed to hear about the winter control mode being active below 5C (40F). It was for those situations I used to grill block on the Gen 2 and Gen 3!
    Are any of you who have these active shutters going to be grill blocking yourself below these temperatures, and if so, by what method?
  7. GreenJuice
    195
    127
    London, UK
    Oops, should have spelt that 'grille'!
    RCO likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Perhaps we could harvest wayward pedestrians using our stealth mode. That should block the air vents suitably! :sneaky:
  9. Tideland Prius
    16,615
    It's still mostly closed (until they come up with a heated grille shutter option).
    kithmo likes this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Perhaps the owners closest to the Arctic circle will be the inventors and instigators of an improved method. I shudder to think how cold it gets way up north, ( no, I don't mean Yorkshire @kithmo)!
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Aye, it's grim up north lad, I wouldn't be surprised if my grill shutters seize up eventually with my low miles and short journeys.
    Snowboy and RCO like this.
  12. KV55
    KV55 Member
    126
    43
    Excel
    Perhaps with the cold mornings here in the UK the 5C partial close will soon come into effect, if they stay in that position at slow speeds it might help steady the fall off in mpg. Something to watch for.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Last winter in Cornwall the car reported average fuel consumption between 55 & 65(UK)mpg and that was on the first 6 months of ever driving a Prius....
    .. and No, I don't dawdle behind the wheel.
    kithmo and Prodigyplace like this.
  14. Starship_Enterprius
    Starship_Enterprius Active Member
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    What about wiring a small heat source near the ambient temperature sensor to fool it into thinking it's above 5c.
    MidwesternBlackSheep likes this.
  15. Trollbait
    12,676
    Likely simpler to just modify the signal coming from the sensor to say that the temp is over 5C.
    The servos probably aren't strong enough to open the shutters in the event the lower grill becomes clogged up with snow and ice Thus the reason for the winter mode. When it is that cold, blocking the front of the grill is the KISS solution over messing with the sensor.
    Mendel Leisk and fneil like this.
  16. Fester
    Fester Active Member
    201
    198
    Ohio
    There's a new video on YouTube from WeberAuto on the gen 4 (2017 Eco) that shows and tells you just whats in the entire cooling system including a segment on the active shutters. Starts around the 12 minute mark.
    If you really want to know the how and whys of our Prius's, these videos are very informative (highly technical too, as they're targeted at automotive techs, but good for the owner to know to in case something stops doing what its supposed to do...
  17. dstahre
    dstahre Member
    74
    35
    Cahokia
    Four Touring
    Thanks for posting. I had already found some of the Weber videos. Only complaint I have is that he talks VERY slowly! :)
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I suppose if he spoke faster there'd be a huge gap before the end of the clip. :ROFLMAO::ROFLMAO::ROFLMAO:
    dstahre likes this.
  19. Tideland Prius
    16,615
    speed it up to 1.25x?
    kithmo, RRxing and Prodigyplace like this.
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That your best shot to get viewers back to eating time on PC? :ROFLMAO:
    Edit: wasting time, LOL!!
    #20 RCO, Jan 13, 2018
