More Trunk Light!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Larry_R, Jun 29, 2007.
  1. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    Yo - I've tried to work in the trunk at night. NOT. Soooo - if I get a flat on a dark road and need to actually see the tools and spare tire? Ummmmmmm. . . . .that liddle side light is pretty useless. SO
    I awayed to Home Depot, and bought some of those neat-oh little "Stick-n-Click" LED "hockey puck" lights. Am sticking two of them on the lower part of the hatchback, where I can easily and simply push on their lenses to turn them on. The light - which admittedly is not super-bright - shines right down on the cargo area. You could put three or more in a row.
    [attachmentid=9306][attachmentid=9307]
    Now - I hope these pics come through - I'm only guessing here. . . . .gulp.
  2. Swanny1172
    Swanny1172 New Member
    666
    I just bought something similar to those to use in my home. The only difference was that they had 5 LED's and 2 different brightness settings. You can also pivot them to direct the light.
    The are 3 for $14.99 at Wal-Mart, but I am sure you can find them elsewhere.
  3. ohershey
    ohershey New Member
    632
    Simple and cheap, yes, but kind of ugly.
    I know, my obsession with physical appearance is probably shallow....
  4. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    Would love to compare the relative brightness of our two products - have not seen the second kind, but will surely look.
    As to "appearances?" - well, uh, how many times do you stare up at the underside of the hatchback? Probably not too many times a day. The light is well hidden - and at least mine come in a whole bunch of colors (the case,not the LED)
    To each his/her own - I just needed some more light! Hope my (our) suggestions may have helped some Priusites "see the light." (ouch)
  5. Swanny1172
    666
    One idea would be to add some velcro to the back of the puck lights so that you could stick them to the tailgate when you need them and store them when you don't. You wouldn't need both sides of the velcro, because you would use the material on the tailgate trim as the other side.
  6. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Mad Hatter @ Jun 29 2007, 10:12 AM) [snapback]470107[/snapback]</div>
    I can't help with cheap and easy... I only do expensive and complicated. ;)
  7. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    The Stick-n-Click lights are so inexpensive and inconspicuous once installed - why not just, well, "stick them" and leave them alone? Aside from changing batteries (3 AAA cells) every year, that is. Once in place, you'll never notice them - until you need some light "back there." Especially if you buy the ones with the black cases.
  8. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    MAJOR UPDATE, PLEASE.
    After I worked with the Stick-n-Click lights, I thought I needed yet another one, so my dear wife offered to go to Home Depot to get one.
    When she returned, she brought THREE new black lights - but they were NOT the Stick-n-Clicks. She said she thought the new ones: Sylvania DOT-it lights, would be brighter and better.
    We did A-B-A comparisons - and she was right! The DOT-it lights have three LEDs vs. the single one on the Stick-n-Click lights.
    I strongly urge you to go with the Sylvania DOT-it lights - IF you even want to bother. I've got two of them now mounted on the lower hatchback, and though not terribly bright, they are enough to light up the cargo area after dark.
    When they're off, you just never see them. I mounted them with three small dots of Velcro, so I can easily take them off for battery replacement. The DOT-its require you to use a small Phillips screwdriver to get at the 3 AAA batteries inside. A minor nuisance.
  9. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(Mad Hatter @ Jun 29 2007, 11:12 AM) [snapback]470107[/snapback]</div>
    Wow I agree these are way too ugly to even be in my house.!
  10. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    Ugly is in the eye of the beholder!
    Here's my installation on the Prius hatchback of two black Sylvania DOT-it LED "hockey puck" lights. Push to turn on, push to turn off - they shine down in the cargo area quite nicely. And come off easily - they're on with black Velcro. I love them, even if anybody else doesn't! (double grin)
    [attachmentid=9343]
    Forgot the "wide shot" here it is.[attachmentid=9344]
  11. count_on_mike
    count_on_mike Junior Member
    Sunnyvale, CA
    How did you get the black velcro to stick on the interior plastic panel? I have the Costco 5 LED pucks and cannot get the velcro to stick to the panel for more than two days. The light, with all of the velcro, falls off the back panel during a warm day. I have used alcohol to clean the surface and that doesn't help.
    Mike
  12. ohershey
    ohershey New Member
    632
    <div class='quotetop'>QUOTE(Wryter @ Jul 1 2007, 11:11 AM) [snapback]471081[/snapback]</div>
    I have to say that the black lights on the black interior appear slightly less ugly to this beholder - now if you could only find them to match other interior colors, you might be on to something...
  13. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    This is a great idea!
    I'll have to look for those the next time I'm following Dear Hubbs around Home Depot :D
  14. Tideland Prius
    16,148
    <div class='quotetop'>QUOTE(Rae Vynn @ Jul 2 2007, 02:35 PM) [snapback]471803[/snapback]</div>
    Ditto!
  15. desertbriez
    desertbriez New Member
    376
    ok...... i went in lowe's to pick up some dot it lights and couldn't find them (didn't feel like tracking down a person to ask.... which section are they in?
  16. Conine
    Conine New Member
    70
    <div class='quotetop'>QUOTE(desertbriez @ Jul 2 2007, 08:36 PM) [snapback]471924[/snapback]</div>
    im heading to lowes right now , ill let you know!
  17. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    First, I got them at Home Depot - not Lowe's.
    Second, my wife came home with a card full of Velcro "dots," about 3/4 of an inch across. I cleaned off the hatchback with Fantastik, then with alcohol on a clean microfiber towel. Let it dry, then stuck three dots on each light, and just stuck them on the hatchback.
    I just went out to the garage, and they're still stuck nice and tight. My wife LOVES the light that they shed on the cargo area. She's an artist, and has to carry a lot of stuff around. The OEM light just made her crazy - it's turned off for good!
    Sylvania makes the DOT-it in many colors - you might well find some that match other car interiors, I'm not sure of that.
    BTW - I accidentally left one of the lights on after I cleaned it - and the next morning it was still shining brightly. I didn't take a chance, though, I pulled it off and replaced the three AAA batteries inside. Takes a very small Phillips screwdriver - and to get the sticky back off, insert a pointed object of some sort in one of the screw holes - then gently pull out.
    Oh, yes - there are two "grades" of Velcro. Get the heavy duty version - it's extra-sticky and stronger.
  18. Conine
    Conine New Member
    70
    found mine at lowes in the first aisle (im sure that will very by store) by all of the other portable lights. they only had a couple left, but i found the sylvainas for $8 each, bought two and put them above the storage unit in the back and where the battery is. provides ample light, enough for what i need it for. as for the color i got silver because thats all they had left, but they do come in other colors. i then proceeded across the street to advance auto parts and saw them there too, so you might wanna try there as well.
  19. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    UH-OH!!!! My wife left Cara Verdi out in the sun most of the day while she was working. When we opened the hatchback this evening, we found that the Sylvania DOT-it lights had SLID down the hatchback about 3/4 of an inch. Almost un-glued themselves. SIGH. What to do?
    Well - obviously in the Flawed-duh! heat, these ain't gonna work!
    So - will away to Home Depot in the morning - get some very thin screws - drill two holes through the DOT-its - and just screw them onto the hatchback. WILL POST PICS.
    Got all the glue-gunk off today, and now will carefully drill and screw the two lights onto the hatchback. I have some rubber shelf liner on the backs of the lights to cushion them a bit.
    AGAIN - will post pics of the "operation" tomorrow (Sunday)
    When good ideas go bad. . . . . . . . . . . .double sigh.
    Meanwhile, got the bright blue LEDs in the front door light fixtures. WAY COOL! Wife luvs them!
  20. orionll
    orionll Active Member
    1,115
    I have similar lights (similar to the ones that Swanny1172 mentioned (bought @ Costco)) and tested the Velcro (the rough, hard side) and stuck the velcro to the Prius (the soft fuzzy area next to the OEM trunk light) to test if it would hold. It did hold, but I felt as if the soft, fuzzy wall in the Prius was being pulled by the Velcro. I'm sure it would hold there, but I didn't think it would be good for the Prius. Just my comment of where you might stick these lights.
