Most important maintenance?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mr. King Andrew, Oct 3, 2019.
  1. Mr. King Andrew
    Mr. King Andrew Junior Member
    17
    I have a 2010 Prius Five that I recently bought that just passed 150,000 miles.
    It has had literally no major service reported at all in the Carfax or in the Toyota service history. Basically just oil changes, cabin air filter changes, and tire rotations.
    I just got the spark plugs changed with new ones, and put a new K&N engine air filter in. I wanted to get some other services done, mainly fluid changes. Am I missing something that may be more important that I should consider doing first?
    • Engine coolant change
    • Inverter coolant change
    • Transmission fluid change
    • Brake fluid change
    I want my Prius to live a long and healthy life. Am I correct to prioritize major fluid changes?
    mikey_t likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Egr circuit cleanse ;).
    Enjoy your new to you Prius (y).
    SFO, Mr. King Andrew and mikey_t like this.
  3. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    Change all of the fluids. Run BG EPR before your next oil change, then add MOA and 44K afterwards to clean out the engine and fuel systems. Keep an eye on the dipstick for the next thousand miles to see if you're burning oil. And definitely clean out the EGR circuit to potentially mitigate any issues with your engine.
    Have the brakes, struts, and tires checked as well.
    Mr. King Andrew and Raytheeagle like this.
  4. Mendel Leisk
    38,720
    Your bullet point list is good. I'd add a FULL brake inspection. That's supposed to happen every 30k miles or 3 years, according to Toyota USA. .
  5. bisco
    49,481
    if it aint broke...
    Sharnold likes this.
  6. Sharnold
    Sharnold Active Member
    379
    119
    Alabama
    Unless it's been totaled and repaired, damaged in some way, something major in the past redone, or not showing signs of something needing service other than the norm. I'd say drive it and maintain its regular services..... oil, filters, tires, brakes......etc
    The stealership has all sorts of garbage maintenance scheduling so they can line their pockets.
