Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    And,If per chance, Your wife unlocks the car remotely, Then remembers something to go in the house for and tosses her purse in an open window with the fob in it. Your car will re lock in 60Sec. even with the key fob in the car!
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    Are you sure it will relock with the key fob in it? I have not done that.
  3. Sampino35
    Sampino35 Junior Member
    23
    NC
    Ha ha! Ill have to try that. I always thought the inner sensors would detect the key fob and not allow it to lock, but, hey, at least your window was open!
  4. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Yah, I first found out about this on my Wife's 2012 Camry but,It also works on my 2010 Prius.
  5. Nora
    Nora Member
    128
    44
    CO
    I finally tried to lock my fob in the car a few weeks ago. I was pleased to discover that I couldn't do it. 1: leave fob on seat and touch door handle to lock. Beep beep, and door wouldn't lock. 2: leave fob on seat, open a front door, press lock button on armrest, close door. Door locks, but then a couple of seconds later, it unlocks. Yay!
    I haven't tried unlocking without opening the door and then tossing fob through the open window. I can't think of any time I have locked my car with the window open more than a crack. I suppose I could push the fob through the cracked rear window (I do this a lot to reduce heat), but that would be pretty odd.
  6. fuzzy1
    10,654
    Just beware that this isn't 100% foolproof. A very few members have discovered interior locations (not the front seat) where the car cannot detect the fob, so can lock it inside.
    Nora likes this.
  7. Okinawa
    Okinawa Senior Member
    1,333
    320
    The guy better let the better half win or there will be big problems.
  8. CR94
    CR94 Senior Member
    2,793
    1,227
    Northwestern S.C.
    1. If you use the fob to try to unlock the car when it's already unlocked, the car will beep-flash 4 times, instead of the expected 2 times (if you've pressed the button twice to unlock all doors).
    2. The right wiper blade's pattern of motion is controlled by a fancy 4-bar linkage, not the usual single pivot for the arm. Thus the blade's wiping pattern is not a simple circular arc as usual.
    3. The right wiper arm is designed such the spring that maintains downward force on the blade is under compression. Very strange! (The corresponding spring for the left arm, and the spring in every other wiper arm I ever studied, is under tension.)
    Correction of 3-29-15: Changed "left" to "right" and vice versa; I had confused sides.
    #868 CR94, Mar 25, 2015
  9. Garth020762
    Garth020762 Junior Member
    I think its cool that my Prius recognizes me as the owner of the FOB key and the interior lights up as I walked by / up to my car. Nice safety feature!
    retired4999 likes this.
  10. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
    In ECO mode the car lets the ICE temperature fall to between 30C and 40C before it switches the ICE on to heat up again. It heats the engine up to between 50C and 60C before it switches off. I guess that is part of the ECO mode's operation to get better economy.
    In Normal mode the car starts up the ICE when the engine temp reaches 50C and runs until it is over 60C.
    How do I know this:) cosy warm camping in the car on a -2C night with nothing else to do but watch Torque. LOL
    Nora, retired4999, markabele and 3 others like this.
  11. bbcnutt
    bbcnutt Junior Member
    Saint Louis, Missouri
    Little known fact: You can put a bottle of champagne in the glove box.
    ITBland and Nora like this.
  12. DavidA
    2,349
    1,825
    Chicago western burbs
    ^ Did that. If you look at my gallery pics, there should be one like that in there.
  13. qdllc
    qdllc Senior Member
    1,377
    400
    Let me know when you fit a tapped keg in the center console. :p
  14. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Here's one I just noticed... The right rear quarter window has electric defrosters. The driver's side does not.
  15. El Dobro
    El Dobro A Member
    7,102
    3,282
    IIRC, that's a radio antenna.
  16. Prius Maximus
    956
    811
    Northeastern IL
    Interesting. They look exactly like the rear defrosters.
  17. Tideland Prius
    16,657
    Yeah it's the "diversity FM" antenna
