Most Toyota Prius Problems and Common Complaints 2000-2017
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusplus_fr, Aug 16, 2018.
  1. priusplus_fr
    priusplus_fr Junior Member
    29
    23
    France
    2012 Prius+ MPV
    RMB and jerrymildred like this.
  2. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    When was that article written? There's been several recalls and issues and technical service bulletins related to the 2016/2017.
    52,353
    before those, apparently. looks like a toyota mia culpa for what is already known. is this a european thing? not sure about 2003-2009, n/a would be 2004-2009. or the piston rings from 2010-2015, someone posted a tsb for 2010-2014 today.
  4. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Haven't red on here replacing their own prius piston rings.
    "Clogged Piston Rings: Toyota gave 2010-2015 Toyota Prii thinner piston rings and an updated piston design, both of which turned out to be not so effective. As a result, the Prii in this generation are prone to clogged piston rings, which leads to excessive oil consumption. Many Prius owners have found success by replacing the piston and piston rings."
