Motor blower controller
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, Oct 15, 2021.
  1. lexidium
    lexidium Active Member
    284
    133
    manchester
    How do you test it out of the car with a multimeter?
  2. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
  3. ChapmanF
    17,326
    Long-time member hobbit described the thing pretty thoroughly here (in the context of building a hack to control the blower while the car is off, for camping).
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,962
    1,911
    NJ-USA
    You can't really test the blower controller that way. It has to be connected like it was in the car- power, ground, and control signal (variable duty cycle squarewave) going in, and a load (blower) on the output. Then see if it works.
  5. ChapmanF
    17,326
    In a pinch you might use something like a headlight for a load. I see in hobbit's write-up that about 5 kHz works for the control signal, and more low time in the duty cycle translates to more output. Pinning the control input to ground could be an easy way to get max output for a quick test.
  6. lexidium
    284
    133
    manchester
    I've now realised how stupid I am.
    I was talking about the hybrid battery controller and thinking it was the same as the A/C blower controller which it isn't.
    It's the black one in there
  7. ChapmanF
    17,326
    I do believe they work pretty much the same way.
