Tags:
  1. CelebrationJoe
    CelebrationJoe Junior Member
    South Jersey
    I have 145K on my 2006 and have been changing the oil on a 3K interval using regular standard oil with no leakage or burning. Please give me your opinions on switching to a "high mileage oil blend" or synthetic. I am hoping to get 250K or more out of my 2006. Thank you.
  2. Former Member 68813
    3,524
    981
    US
    apparently you are doing the right thing. i would personally extend the interval to 5,000 miles using quality oil (major brand, API starburst, etc). "high mileage" is only helpful when you leak or burn oil. synthetic oil is not the best choice on old tired engine (can increase oil consumption).
  3. Mendel Leisk
    38,895
    If you're not consuming a lot of oil, there's no point in going to oil described as "high mileage". The dirty secret of those oils: they swell (rubber) valve guides. Once you start using such oils, return to regular oil will cause the guides to shrink back, with much higher oil consumption.
  4. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I started using Castrol GTX High Mileage oil in my old Toyota Corolla at about 160k miles after it had started to use oil (slightly), the GTX HM fixed the problem and I drove the car to 292k miles at which point it failed the state-inspection (body corrosion), but the engine still ran as sweet as ever, and started first time, every time!
