motor stall pcv valve
Discussion in 'Generation 1 Prius Discussion' started by nightmare66, May 25, 2017.
  1. nightmare66
    nightmare66 Junior Member
    24
    Kentucky
    2001 Prius
    I
    motor stalls when i pull the pipe off, is that normal? there a misfire
  2. ChapmanF
    18,555
    That's a pretty big hose that would let a lot of unmetered air in if you pull it off. You'd stall too if somebody did that to you.
    -Chap
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Normal. And a leaky PCV will set a code, too. Don't ask me how I know, but glad that the hose in question (for an early millennia Taurus) is available in the 'HELP' section of the local autozone.
