Mountain Passes
Discussion in 'Gen 2 Prius Main Forum' started by Silverback, Nov 2, 2004.
  1. Silverback
    Silverback New Member
    29
    Kelowna, BC
    I live in the Okanagan Valley of British Columbia and on trips to Vancouver have to climb go over a couple of fairly significant passes. The longest climb is about 30 km of 6% grade. Speed limit is 110 km/hr. What can I expect?
  2. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    Before we picked up our car, and whenever we met a Prius driver, we would give them the third degree about the vehicle. On one occasion about two months ago we met a couple on Vancouver Island with Alberta plates so asked how their trip was. That had been their first trip of any distance and reported that from Calgary to Vancouver, maintaining posted speed limits using cruise control they averaged 4.8L/100km ( if my memory serves me correctly.... I posted this info in one of my earlier contributions and had a quick look through my previous posts but couldn't find it)
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    On very long steep uphill grades you can expect to deplete the battery SOC to a point where you're essentially running on ICE power only. You will be able to maintain speeds in the 50-55mph range. The ICE will be wound up to some pretty high RPMs to do it, but without harm to the system.
    Of course on the downhill the battery recharges quickly. See if you can get a TRAC/rental and drive it on your route to see how it does.
  4. bflat58
    bflat58 New Member
    Denver, CO
    I live in Denver and have taken my 04 across the Colorado, climbing several passes. Yes, the battery does drain to nothing on long climbs and the ICE works its little heart out, but I was usually able to maintain 50 mph. Its a little humbling to move to the far right lane and get passed by those stinking SUVs. However, the downhill glide is fun. I once made it for 12 minutes without the ICE coming on and had rare full green battery! I played a little with the brake mode, but am not convinced it buys you much. I averaged 57 mpg on one long mountain trip, so the downhill savings seem to outweigh the lower Mpgs when climbing. I did not buy my Prius to drive in the mountains, but it does OK when needed.
  5. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    By prudent driving (cruise control @ about 41-55 mph) more or less on the level, I always obtain a green battery after 25 minutes of driving on my morning and evening commute. I can drive an older section of highway that parallels the newer faster section. Fuel economy averages 53 mpg and the battery stays topped off.
    Several posts discuss "feathering" the accelerator to obtain optimum fuel economy and battery recharge. In a Prius you learn to "read the landscape" and drive appropriately, rather than substituting oil for knowledge. As needed, you accelerate to stay with fast moving traffic, but overall there is great satisfaction in applying knowledge rather than oil. Going over mountain passes is a bonus that reinforces good driving.
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    It doesn't buy you something, it saves you from riding the brake pedal all the way down the hill. :)
  7. bflat58
    bflat58 New Member
    Denver, CO
    True. However, I found that for my mountain driving it slowed me up a little too much, too quick and I had to hit the gas. I think it depends on the pitch of the hill.
  8. Canuck
    Canuck Member
    605
    I don't know if is a good thing to do or not but in our local mountain downhill runs I "feather" in and out of "B" to maintain the speed I wish to keep, not using the foot brake nor the gas pedal.
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    haven't done the C with the 2k4 but the 2k3 no problem just drive it normally and it's ok. Mine hill on 3 no problem it'll do 135-140 up there like nothing. Both of them, it's no big deal. Been to Alberta and Sask with them no problem on any pass, Rogers, or Kootani pass nothing but clear sailing, if fact I was passing the ones that thougt 115 was to slow on the Coq and passed me at the bottom. 115 at the top and they were looking at me kinda strange as I was going past them. It's very capable on any road in BC.
  10. ggrimaud
    ggrimaud New Member
    36
    Reno, NV
    I occasionally drive from Reno to Sacramento. I drive I80 over Donner Pass. I set the cruise control and then enjoy the ride... That is until I noticed that I was gaining speed going down the other side. I have to switch to B and even then I have to brake occasionally. As far as the up hill side though, I haven't had any problems at all.
    I just wish that the cruise control was smart enough to engage the B mode by itself. I guess if I wanted a car that totaly drove itself I'd hire a Limo...
  11. Silverback
    29
    Kelowna, BC
    Thanks Frank. That's very encouraging. I test drove a 2K4 up a steep stretch of Hwy 33 outside of Kelowna and was amazed at how easily it climbed. My other vehicle is an 03 Tundra and this is a hill that causes this V8 truck to gear down to keep up to 90 kmph. The Prius just flew up that hill. However I was concerned with how it would do on the Connecter and the Coquihalla. The grades there are fairly steep, but it's the length that made me wonder. For those that don't know BC, the Okanagan Connector is the highest pass in BC The altitude gain is over 4000 feet from the bottom of the valley to the top of the pass. The return trip of of course is great for fuel economy!
    I've got an 05 Prius on order...I initially had my heart set on a Subaru Forester XT but the more I looked at the gas mileage data on that one, the more my enthusiasm dampened. One gas hog is enough...we'll park the Tundra and drive the Prius unless we really need a truck.
    Cheers,
    Bill
  12. Silverback
    29
    Kelowna, BC
    Wow. At first I thought you were saying you drove 180 km/hr over the Donner Pass. That had me really impressed. Then I put on my glasses... Still, I'm glad to hear that you've found the Prius to be a capable performer in the mountains.
    Cheers,
    Bill
  13. ggrimaud
    ggrimaud New Member
    36
    Reno, NV
    I should have been more clear. I generally set the CC to 70 MPH (114 KPH). There is plenty of power left so that I could go faster if I wanted to end up at the bottom of a deep gorge! It hadles like a Prius after all.
  14. Silverback
    29
    Kelowna, BC
    No, you were clear enough. I just read the I-80 as 180.
    Cheers,
    Bill
  15. bruceha_2000
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Certainly true. And as Canuck stated, you can jump between B & D as needed. It isn't nearly as gripping a feeling as dropping a gear for the same purpose in a regular automatic or manual tranny. :) You will love your car!
  16. metamatic
    metamatic Member
    114
    16
    Austin, TX
    2020 Prius
    I drove through the Blue Ridge Mountains in a Prius fully loaded down with worldly possessions (both rear seats folded down and I could barely see out the back window). Also took the Prius 6000' up the Smoky Mountain range. Still got 45mpg average.
  17. aforkosh
    aforkosh Active Member
    413
    262
    Oakland, CA
    2023 Prius
    I drove a round trip this week over the Sierras between Oakland, CA(100' above sea level) and Reno, NV (4500'). The trip was about 200 miles each way with the peak elevation of 7200' reached about 45 miles west of Reno. I was able to keep the car above 60 mph the whole way. Milelage going to Reno was about 44 mph. The return trip (including 25 miles around Reno at 40 mph--it was rainy and snowy there) came in at 53 mph. Near the summit in each direction, the battery level dropped to 2 bars.
    The weather was clear with a headwind going to Reno, while on the return, the mountain section was on recently plowed freeway and through some falling snow (warm enough to liquify immediately on pavement) on the downgrade below 5000' and above 3000'.
    Around home, the battery level seems to stay around 6 bars. Around Reno, where the air temperature was 20 to 30 degrees cooler (in the 30s and 40s), the battery level seemed to home at 4 bars.
  18. Tideland Prius
    16,159
    Just a thought,
    I was going down a moderately long stretch of road downhill and thought I'd engage B to see what it would do. Now I know it simulates engine braking but has anyone noticed that the Prius "jerks" a little? (I guess rock is more appropriate than jerk) It sorta feels like someone is pumping the brake pedal - gently, of course.
  19. Steve Goldenberg
    Steve Goldenberg New Member
    126
    Aspen, CO
    I picked up my 2004 #9 in Houston on 12/27/03 and drove 1,000 miles to Denver without any problems. From Denver to Aspen was a different story as there are 2 or 3 long, steep straight mountain passes. It was cold, snowing with at 35 mph headwind. The Prius was fine for the first five minutes of each pass and then on we were on ICE only with lots of traffic. It wasn't fun as we couldn't keep up with traffic. Going down each pass quickly filled the battery but there just wasn't enough capacity to make it up the other side. Other twisty passes are fine because the ICE can generally do 60mph, which is more than necessary on curvy roads. Subsequent similar trips were not quite as bad especially in warm weather, without the snow and snow tires. All in all it's OK for occasional passes but I would use my Subaru if I had to do it regularly in bad weather. This is the only performance issue with this car. Otherwise it's great.
