Mounting A Garmin GPS In A Gen 5?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by VelvetFoot, Sep 18, 2025 at 8:24 AM.
  1. VelvetFoot
    VelvetFoot New Member
    Yesterday
    New York State
    2025 Prius
    I'm in the market for a Gen5; LE's seem to be hard to find around here.
    Anyway, my Garmins have been good to me. On the one hand, they require no cell connection, and on the other hand, they don't provide updated info, at least the ones I've owned.
    Has anyone mounted one with the suction cup on the hugely-raked windshield? It seems like it could be problematic.
  2. BiomedO1
    BiomedO1 Senior Member
    3,078
    1,633
    SacTown, Ca
    No Problems here.
    All Garmin come with lifetime map updates. Depending on the model, the high-ones; you simply input your WiFi login and password - as soon as it sees it, the updates are automatic. The cheaper models will require you to plug it into your computer for updates. Just follow the instructions on your computer screen. Warning; it's going to take a few hours if it's your first time. Subsequent updates will take less than an hour. You'll need at least an 8GB micro-SD memory card, if your going to load maps for the entire USA onto it.
    Hope this helps.....
    FYI; the new software prevents you from making route changes "on the go"; you need to pull over and stop to make changes.
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    667
    265
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I have a Garmin nuvi 2957 for about 10 years now and love it.
    We have used it all over the country and Canada.
    I use the bean bag mount and just set it on the dash were it's convenient.
    I do a manual update about once a month or before a trip.
    #3 bat4255, Sep 18, 2025 at 10:50 AM
  4. BiomedO1
    3,078
    1,633
    SacTown, Ca
    I personally don't like those because I'm in the mountains a lot. They tend to slide across my dash when I take a turns or go around hair-pin turns - then everything goes wonky until a stable GPS signal is reestablished. That gets tricky under partial tree cover as your moving.
    Another option is those suction-cup articulating/extension mounts. I don't like those either because the arm tends to exaggerate the car's suspension movements. All that movement and bouncing around gives me a headache after a few hours, but your brain may not be sensitive to that. I can't read while in a car either, same thing happens to me. Planes and ships, no problems.
    YMMV
