Mounting new set of Prius wheels that comes with tpms sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amati5, Mar 14, 2016.
  1. amati5
    amati5 Junior Member
    58
    So Cal
    most people change to after market wheels and from what i read, they have to transfer or get new sensors. I am looking at the same Prius set of wheels and tires with the sensor and wonder if i need to do anthing. Will the tpms recognize the new sensors right away? What about the set from a Scion that also comes with sensors.
    Thx
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    you can transfer your old TPMS sensor to the new wheels.
  3. fuzzy1
    10,167
    No. Without re-programming, it will never recognize any other sensors whose serial numbers do not match those programmed in at the factory.
    Some aftermarket sensors can be cloned to match previous serial numbers, so the car does not need reprogrammed.
    Some other TPMS systems can auto-recognize new sensors. The Prius does not have such a system.
  4. amati5
    58
    So Cal
    Thx for the info. I wonder if we can transfer the sensors ourself without removing the tire off the wheel completely. It seems possible with just pushing the tire down to expose the sensor.
  5. NutzAboutBolts
    1,476
    1,552
    Bay Area
    its possible, you just have to press down hard enough to reveal the sensor to remove it. Make sure not to drop it inside the tire, or else you'll have to remove the tire to retrieve it.
  6. amati5
    58
    So Cal
    The sensor is part of the valve correct,? I saw on youtube the person remove the sensor across from the valve, a flat blue device. Is it a typical sensor?
  7. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Yes the sensor is part of the valve,but the Toyota sensor is helded on by a 10mm nut from the outside. Once you remove that nut, the sensor falls off... So make sure to reveal the sensor from the inside and hold onto it tight before you remove the 10mm nut and washer from outside, or else the sensor will fall and it'll be sucks for you to retrieve that piece... Lol
  8. amati5
    58
    So Cal
  9. fuzzy1
    10,167
    I'd think that the labor cost of this would exceed the cost of having a tire shop read the new sensors (handleheld device that reads the RF signal through the tire sidewall) and reprogram the car (plug same device into the OBDII diagnostic port, push a few buttons).
    When I bought new rubber from Discount Tire, mounted on rims immediately but installed on the car a few months later, the aftermarket tools I had couldn't read one sensor. Discount read and reprogrammed everything in a couple minutes (free, because I bought the tires from them).
    Earlier, before acquiring said tools, Les Schwab would have charged $20 to read and program a set acquired online for another vehicle. This failed only because the vehicle was newer than their tool software revision. Vehicle dealer charged $70 :-( (which is why I bought said tools, which work well on that rig).
  10. Mendel Leisk
    38,721
    Just for the record, the car will function fine with conventional valves, without sensors. Not ideal, but an option.
    Toyota's implementation of TPMS is not owner-friendly in the least, leads to a lot of effort and expense, eclipsing the original intent of the system. Ok, all done, lol.
    CR94 likes this.
