Tags:
  1. Paul Gregory
    Paul Gregory Senior Member
    1,358
    355
    Alberta
    2024 Prius Prime
    XSE
    In my Gen 3 2012 Prius, I had a paper towel roll in the back, and one day, I noticed that a mouse had begun to make a nest out of it. The Prius is quite well sealed from the outside, but there is a plastic vent panel with small slots in it, I assume for ventilation. A mouse had managed to gnaw through it, just enough to squeeze through. I suppose that panel should have been made of metal. I cemented a metal mesh from a window over it, and that seemed to do the trick.
  2. Mendel Leisk
    40,456
    You’re talking about the vents in the rear corners, below hatch floor?
  3. Paul Gregory
    1,358
    355
    Alberta
    2024 Prius Prime
    XSE
    Not below any floor as I recall, but accessible from inside the rear space. It was a pop-out panel made of some sort of hard plastic.
  4. Mendel Leisk
    40,456
    Take a picture? AFAIK the only openings near the rear are the two exhaust grills. They have little flaps. Most effective way to screen I found was taking the rear bumper off, putting anti rodent mesh on the outside.
    The usual place they come in is the cabin air intake, on the firewall behind glove box. Maybe pull the glove box and check for evidence, seeds and junk on the air filter.
    #4 Mendel Leisk, Jan 12, 2025
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,342
    2,337
    Taylors, SC
    I made a post a couple of years ago on how I pried out the plastic exhaust vents from the outside and fastened screens onto them before putting them back in place.
  6. Mendel Leisk
    40,456
    I caged the outside.
  7. Paul Gregory
    1,358
    355
    Alberta
    2024 Prius Prime
    XSE
    I sold that car last year. I'm wingin' it from memory here.
    And it's not that good anymore.
  8. Mendel Leisk
    40,456
    Join the club lol. (y)
