Mouse proof the cabin air intake
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by df_252, Jul 8, 2020.
  1. df_252
    df_252 New Member
    wv
    I decided to do the hardware cloth mouse proofing of the cabin air filter. Removed the wipers, cowl cover and wiper motor/transmission. When I looked at the opening on the passenger side, I could see that there was a "secondary firewall", behind the firewall that has all the holes in it. This secondary firewall has a long hole directly in front of and above the cabin air filter. I believe that covering this hole with hardware cloth will completely protect the cabin air filter. I cut a 3-1/2"X17" piece of 1/8X1/8 hole hw cloth and slid it into place. I was able to put a couple of screws in through the existing hole. I then drilled out the round hole at the passenger side of the firewall and, using a long driver put a screw in at that end and then I drilled a 1/2" hole midway and put another screw in there.
    The problem with covering just the big holes in the firewall is that there are access points from the wheel wells that are inaccessible to plug. I then screened off the holes in the firewall and stuffed steel wool in the round holes in the hood mounts where the red wire is passing through. I did this to try to keep mouse nests out of the cowl area.
    This is the hole behind the firewall
    Screen in place between firewalls
    Wire shows access from engine compartment
    IMG_5079.JPG I
    Screen on secondary firewall visible through large hole.
    #1 df_252, Jul 8, 2020
    bisco, ydpplqbd and SFO like this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    I wouldn’t use steel wool it will quickly rust and disintegrate and make a mess.
    Open the hatch look under the spare tire see if the rubber drain grommet is still there look in the 12 volt battery hole and see if any water in that hole, there’s 2 vents in that area to vent compression air when you slam the hatch. There’s also a vent for the hybrid battery fan. Don’t block any of those.
    Look for mouse poop back there too. Miss Cyberprius should come by soon and weigh in she’s a mouse expert.
    49,478
    well done!(y)
    you're a better man than me. i just put up with the dead mouse smell :oops:
  4. Mendel Leisk
    38,718
    This stuff looks interesting:
    Or maybe they'll drag it off to make nests, lol?
  5. edthefox5
    10,096
    4,806
    Clearwater, Florida
    ,yes better than steel wool that’s rusts over night.
  6. df_252
    df_252 New Member
    wv
    Steel wool was a quick fix for those spots. I did pour some used motor oil on/into the steel wool as a rust preventive...
