Move up the Rear-View Mirror for better forward vision
Discussion in 'Knowledge Base Articles Discussion' started by Solar_Powered, Jun 1, 2006.
  1. Solar_Powered
    Solar_Powered New Member
    38
    Cypress, Southern California
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    A much simpler fix for the non-garage-door-opener mirror is to turn
    it upside down and push it up as high as possible. Would that work
    with the type with the buttons too, if the driver was willing to
    simply use the buttons at the top of the mirror frame? It looks like
    the wire harness would still reach fine.
    _H*
  3. unruhly
    unruhly New Member
    205
    I turned my mirror upside down and the wiring is fine. It's not lifted to it's upper most limit though 'cause if it was, the sensor for the auto-glare would be shadowed by the roof console. I think it actually works better now 'cause before the headlights would be shadowed by the center support of the hatch (between the upper and lower glass). Now the lights behind me shine directly into the sensor. Also, being upside down, the side angles of the mirror more closely match the angles of the rear roof line and provide a much better view out the back.
  4. Padawan
    Padawan New Member
    St. Louis
    Rotating the mirror upside down is a great suggestion. I've driven my Prius for 15,000 miles and, being 6 feet tall, would always have to duck to see what was behind the mirror when making right hand turns. With the mirror rotated upside down, it has easily given me a few precious centimeters of viewable windshield that was previously hidden!
    This is why I read these forums - always learning new tricks to make my driving experience even better. Thanks!
  5. Manksgloob
    Manksgloob Member
    243
    I did this a couple weeks back.
    It's great, I can now see cars waiting to make left turns onto the road I'm on.
    The only caveat seems to be that the viewing angle of the contents within the mirror is dipped, and so part of what I used to be able to see is cut off by the top of the hatch.
    Tilting the mirror slightly downwards to conpensate results in a shorter viewing distance/range.
  6. Catskillguy
    Catskillguy New Member
    536
    Mid Hudson Valley NY
    Wow.. I can't wait to try this tomorrow!!!! (upside down mirror)
  7. Dr Ed
    Dr Ed New Member
    188
    Why are people moving their rear view mirrors upside down to get them higher? For a taller person the stalk must also be adjusted up. The mirror assembly has three pieces: mirror, stalk, windshield mount. The stalk can be swiveled inside the mount just like the mirror can be swiveled on the other end of the stalk. To do this, return the upside down mirror to its regular position. Grasp the mirror on the right and left with both hands. Pull the mirror slightly toward you while pushing straight up toward the car roof to move the stalk until it stops. Then adjust the mirror to the desired position.
  8. georgekessel
    georgekessel Member
    182
    <div class='quotetop'>QUOTE(Solar_Powered @ May 31 2006, 09:50 PM) [snapback]263866[/snapback]</div>
    Could you please repost this - it's gone now :(
  9. Tideland Prius
    16,126
  10. georgekessel
    georgekessel Member
    182
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 17 2006, 05:45 PM) [snapback]320946[/snapback]</div> Ugg, that was the wrong link above - I am looking for how to move my "fully loaded" mirror up as to make it where I don't have to duck around it.
  11. Tideland Prius
    16,126
    oh shoot. Sorry.
  12. Solar_Powered
    38
