Moved my ScanGauge ][ from Gen 2 to Prius v
Discussion in 'Prius v Accessories and Modifications' started by JimboPalmer, Sep 18, 2012.
  1. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    Voltage reads 1.4-14.5 instead of 13.4 - 13.5 This may mean the v will recharge the 12 volt battery quicker.
    Water Temp is 195 instead of 184 and is less constant.
    RPM seems higher at any given speed although I need a larger sample size.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    For the voltage, someone reported that the Gen III has a temperature sensor on the 12V battery. So it charges at a higher voltage unless the temperature gets above a certain setpoint then it drops back to the 13.5 range.
