movies on MFD
Discussion in 'Gen 2 Prius Audio and Electronics' started by unheardthreat, Jan 18, 2006.
  1. unheardthreat
    unheardthreat New Member
    ive seen pictures of people who have been able to watch dvds from the MFD by using a seperate dvd player and tweaking the car a little. does the car have to have NAV in it in order to do this to the car? is there any difference in quality of the MFD with NAV vs. without? i thought it would be cool if i could get this on a package 2 or 3, im too broke for package 8.
  2. tmorrowus
    tmorrowus Member
    514
    NAV is not involved in playing DVDs with a separate player. The nav unit only plays nav DVDs, not movie DVDs.
  3. aaf709
    3,862
    2022 Prius Prime
    You do require an A/V gizmo attached to the MFD to make your connections to your DVD player.
  4. Tideland Prius
    16,127
    Yup. A video controller will do the trick. Then plug the DVD player into the controller.
  5. saechaka
    saechaka Member
    225
    where can you get one of these video controllers for non nav units?
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Before you go too far with this, saechaka, you may want to ask for more opinions. I'm not sure if the non-Nav 2006 Prii have the higher resolution screen. The 2004/5 screen would be unsuitable for TV - too low res and too slow. A slow LCD screen can't handle an image that moves fast without washing out and blurring, the pixels can't keep up with the signal.
    Look in the electronics and audo forum and you'll find lots of discussion about adding video display to the MFD, mostly for a rear-view camera, now available on the 2006, but it's the same little video box that plugs into the MFD.
  7. Tideland Prius
    16,127
    Hmm, but didn't Coastal show a video of him playing some tv sitcom on the MFD when he was running tests of the ViewTech?
  8. unheardthreat
    thats one of the issues i need some answers to. so there is, in fact, a difference in monitor quality from the NAV and non-NAV MFD?
  9. BMcGraw
    BMcGraw Member
    230
    Southern California
    I don't know where you heard that from Bill. I've got a 2004 and a VIDTOY tied into it without any video problems you mention. Maybe I'm just lucky... :rolleyes:
  10. c4
    c4 Active Member
    607
    51
    The standard MFD is fine for video input.. All but the very cheapest NTSC-input LCD panels you can buy on the market today will meet scan requirements for NTSC video, so speed is generally not a problem (with some of these, on very cold days, you may see a bit of ghosting until the monitor warms up), the only real issues are those of size and resolution, but it's actually quite acceptable as long as you realize you're watching on a little 6" low-res screen and not your 55" wide screen and adjust your expectations accordingly..
    I can play perfectly acceptable DVD video on my Classic Prius MFD which is even smaller than the 04/05.. Using the MFD for computer display on the other hand leaves something to be desired as even VGA resolution comes out somewhat fuzzy..
  11. sazzam
    sazzam New Member
    33
    San Dimas, CA
