Moving auto dimming mirror from 2006 to 2012
Discussion in 'Gen 3 Prius Main Forum' started by jmann, May 26, 2017.
  1. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Does anyone know if the autodiming mirror from my 2006 will fit in my "new" 2012? If so, I should transfer it to my "new" 2012 before I sell or trade in the old 2006, right? I can probboly figure out the wiring from this:
    Auto-Dimming Mirror with Homelink for 2012-2016 Toyota Prius v - PriusChat Shop
    Anyone know if it is simply unscrew-rescrew then wire?
  2. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    I simply bought one for about $200 and had it installed (about $100). It may look about the same, but I think there was a change in the buttons so the icon won't wear away like the one in my 2004 Prius.
  3. jmann
    jmann Member
    201
    30
    Cleveland, OH
    So.... the answer is yes. Both mirrors have the same post. They were easily swapped. However, the cheap mirror has a plastic cover that must be popped off and then a latch to slide it off, which was tricky. The auto dimming mirror slides onto the mount and secures with a screw.
    Easily swapped. Next, I have to wire it.
    Where is there an easily accessible power and switched power source?
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Easy. If you need to buy one, it's less than $100. 2 wire install, 1 to ignition or headlight hot, other to ground.
