Mpg and Tank Capacity Measurement
Discussion in 'Gen 2 Prius Main Forum' started by fragglestickcar, Jan 16, 2020.
  1. fragglestickcar
    66
    38
    New York
    Disclaimer: I am not liable for injury, death, or damage from the following. Please suggest safer, better ways of measurement.
    Measuring MPG. Fill up. Drive Y miles where Y > 200. Fill up, and record number of gallons filled X. Divide Y by X. Ideally do all this on a single road trip to avoid temperature effects.
    Measuring tank capacity. Keep a full 1-gallon gas can in the car. Drive until red triangle indicates you've run out of fuel. Drive another quarter-mile until you're on fumes (this damages the car, yes). Pull over and fill up with your 1-gallon gas can. Go to gas station and fill up, and record number of gallons X. Tank capacity is X + 1.
  2. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    You need to add at least 3 gallons for the car to register that fuel has been added, so you need a spare gas can of 3 gals or more.
    nssdiver, srellim234 and SFO like this.
