mpg calculated vs computer
Discussion in 'Prius v Fuel Economy' started by alfon, Nov 4, 2011.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I have heard from Cleanmpg.com , Wayne Gerdes, that the computer is more accurate this time around than the 2010/11 Prius. That this was told to him by Toyota engineers.
    I believe it was off by about 1.5 mpg when Gerdes checked it which is a lot better than mine which is consistently off 3-4 mpg.
    If you have the new Priuv V just fill it up to the top of the neck where you can see the standing gas. Drive for x amount of miles and than refill to the top of the neck again and check your calculated with the computer for verification. Real easy to do, than post your results; it will be appreciated.
    alfon
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yes, I was also told by Toyota while in San Francisco for the launch that the computer has been made more accurate to better calculate mpg.
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Doesn't this go against warnings not to top off your gas tank? Aren't there mechanisms that can be damaged by overfilling?
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    That is what Wayne Gerdes did when tested the Prius v.
    I have filled ours that way once and a while, and no lights, bells, or whistles went off. The tank will hold and extra 2 gallons of gas when filled that way after the first click of the gas pump.
    There is also nothing in the owners manual, at least in the 2010, that states not to fill the gas tank to maximum. If there is It was not printed in mine.
    al
  5. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    My Accord manual says - 'Do not top off the tank. This leaves room in the tank for fuel to expand due to varying temperatures.'
    I would think that's true for all cars, especially with warnings posted at the fuel stations.
  6. easted
    easted Junior Member
    64
    Pillow PA.
    2018 Prius
    mpg displayed 47.2
    mpg calculated 47.4 this is for the first tank refill. I only went by the nozzle clicking off, not filling up to the neck of the tank.
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Any additional stats on computer vs calculated mpg...
    al
  8. Mendel Leisk
    38,644
    With just a couple of fill ups I think any variations in pump shut-off will cancel out. I've never been a fan of filling to the neck, for various negative reasons, not the least of which being it takes too dang long, tends to tick off anyone waiting behind you.
    Also, Toyota says they are making the computer more "accurate"? IMHO, that's a polite way to put it: why is the inaccuracy consistantly, with every Prius owner, in their favour, by 6~8%?
    msirach likes this.
  9. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    It looks impressive for people who don't actually calculate their real MPG.
  10. almypal26
    almypal26 Member
    101
    So Cal
    :)My last tank, computer indicated 60.2 mpg, calculated is 56.3 mpg. 2010 model III, 45,600 miles.
  11. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    It appears that the 2012 Prius v has a more accurate mpg gauge than
    the 2010-2011 Prius models.
    Now, I just wonder if the 2012 Prius willl have the same software for
    their mpg computer gauge. Also, the new and improved 2012 Camry
    Hybrid, these are issues where we should have positive answers
    shortly.
    alfon
  12. easted
    64
    Pillow PA.
    2018 Prius
    After 2300 miles, approx.700 miles on interstate averaging about 65 to 70 mph, the remaining miles in town or 55 mph traveling. Calculated MPG is 45.3. Displayed MPG is 46.6. So displayed is + 1.2 MPG.
    2 people like this.
  13. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    thanks for the info. Our Prius, is off on average about 3.5 mpg optimistic.
    Toyota should apply proper software to make all the 2012 Prius, and
    other models more accurate in the mpg gauge. In fact even the 2010-11 model Prius, now that they know the mpg gauge was inaccurate.
    Most people don't bother to calculate mpg's and rely on the guage.
    alfon
  14. aquapete
    aquapete Newbie Prius Owner
    NE Phoenix area
    I agree with cycledrum. I distinctly remember reading in the owners' manual to NOT top up. There is a flexible bladder in the fuel tank which is supposed to help control fuel fumes. If you top up, you stretch the bladder, causing it to lose its
    function.
    I stop filling the gas tank when the nozzle switches off. My manual calcs differ from computer shown display of mpg by as much as 3-4 mpg, and then sometimes there's hardly any difference at all. I have no idea why.
  15. Mendel Leisk
    38,644
    Your numbers work out to 2.8% error. That's a fair bit less the regular Prius owners are finding. Our error is at 6.4% right now. On the optomistic side, of course.
  16. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    This is a v forum.
  17. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Yup. The EVAP system, specifically the charcoal canister, is not designed to be filled with liquid gasoline. Overfilling can kill it, throw error codes, and eventually end up in an expensive repair which may not be covered by warranty.
    Just fill til the nozzle clicks off the first time (slowing down as you approach full to avoid premature click-offs). That plus making sure the car is level when you fill will be accurate enough.
    If you want even greater consistency you can fill at the same station and use the same pump (not always possible, obviously).
  18. easted
    64
    Pillow PA.
    2018 Prius
    At 4930 miles, My displayed mpg reads 48.0. The calculated mpg is 45.3. It has been running at this 2.6 / 2.7 mpg difference for the last approx. 2700 miles. This is in FL. weather and flat terain for approx. the last 3000 miles.
  19. dk_brookdale
    dk_brookdale Junior Member
    63
    I have had about 10 fill-ups since getting my Prius v. My driving has not changed during that time. The car's computer estimates I'm averaging about 43 MPG. My own calculations with each fill-up shows that I'm getting about 41 MPG.
  20. danbob
    danbob Junior Member
    36
    Westchester NY
    41.9 for the computer, 38.9 for the fuelly.com calculation. This was only our first fill up in the car though so I expect it will get better
