MPG dash calculator broken after IPM replace
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tripjack, May 12, 2017.
  1. tripjack
    tripjack Junior Member
    My House
    So back in January 2017 my 2012 Prius V died on the way to work, turned out to be a IPM failure which my neighborhood dealership fixed for free.
    However since I got the car back, the dash readout for the MPG calculator is on crack. At first I thought I maybe just had to drive it for a while for it to calculate an average again, but here we are 4 months later and I just took a 1000+ mile road trip and it's still totally wonked out. It gives readings, but they're all over the map, sometimes just sitting at 99.9 for a few seconds, then jumping down to zero, then some other random number etc., and it never has an average at the end of a trip.
    I've had the car 5 years, so I know it is not functioning correctly. I've never ever seen it say 99.9 or all zeros on there, and now it's part of the normal, constant, random number selection that seems to be happening. As far as I can tell it's the only thing being weird after that IPM replacement though. Is there any software reset I can do? Or do I need to take it back to the dealership?
    Thanks in advance!
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Take it back to the dealership, repairs are usually covered for 90 days after the work was done. The IPM is covered for longer, but you can try to get your issue addressed under a generic 90 day warranty on the work done.
  3. Mendel Leisk
    38,664
    Is this a "Prius v", ie lower case v, the Prius "minivan"?
  4. tripjack
    My House
    Yes, a 2012 Prius v Five. I made an appointment for Monday morning at the same Toyota service center that did the IPM fix, hopefully they'll take care of it.
