mpg decreased a lot after "stay at home"
Discussion in 'Gen 4 Prius Main Forum' started by gloriarifin, May 6, 2020.
Tags:
  1. gloriarifin
    gloriarifin Junior Member
    san diego
    So I have 2016 Prius with mileage around 60k. I noticed late last year my average mpg decrease to around 50. Before it was around 53. I thought it's about the time, because of the mileages and age. So after the lockdown ( I didn't drive it a lot for a month, just a Lil grocery trip 5 miles round trip vs the usual at least 50 miles a day), when I back to work and normal. I noticed my average mpg drop to around 43. Is it normal? Is it because the car not used every day? But there was no dead battery during those times. I know it's less traffics, so of course, the mpg would decrease. But I feel 43 is too extreme?
  2. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    How many miles have you driven after the "stay at home" period?
    pjksr02 likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    Yep - short trips don't equate to good economy. It'll come good once the Pandemic is over.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I'd take a page from Douglas Adams and "Don't Panic!".
    43 MPG isn't good for a Prius, but sitting for a month and short trips.
    I'd just not worry until your next fill up. See what happens once you start driving more regularly. Hand calculate MPG for entire tanks for a while.
    See whether the MPG improves, stays the same, or worsens.
  5. FuelMiser
    FuelMiser Senior Member
    1,267
    860
    Monument, CO
    Couple of things: 1) when cars sit, tires lose air pressure and flat spot. This increases MPG. 2) When the 12V battery sits, it loses volts and needs more recharge from the hybrid battery. I'm not saying this accounts for a 10 MPG drop in your displayed economy, but it will change it some. Don't panic over a single day's MPG. Only worry about it after a complete fill-up (Miles Driven / Gallons Used). Daily MPG estimates by the computer can vary widely.
    kithmo and Montgomery like this.
  6. gloriarifin
    san diego
    around 800 miles
  7. pianewman
    264
    183
    2018 Prius
    hmm...sooo...more than one tank.
    Have you checked tire PSI? Are you certain that your driving pattern is similar to before the "stay at home"? Ambient temps are warm enough that MPG should be optimum.
  8. husami
    husami Junior Member
    50
    Cincinnati, Ohio
    The biggest issue with the stay at home is the battery draining. I am having the same issue. However, when you drive it for > 10 miles it should start to get back into the average. Check tires and battery state. I use Dr. Prius App and the OBD2 wireless dongle
  9. gloriarifin
    san diego
    The tires should be fine. I just did my tire rotation during stay at home, and they checked and filled the tires
  10. gloriarifin
    san diego
    I just did oil change over the weekend. While there, I asked them to check the battery. The dealer said the battery still plenty of life left
  11. pianewman
    264
    183
    2018 Prius
    I wouldn't trust that they've put the correct PSI in the tires. It's always best to check it yourself, cold tires, in the morning. The general consensus around here is the doorjamb PSI is the MINIMUM, mostly for comfort, and most here put 4-6 pounds more in the tires, for better MPG. You might want to try that.
    As for your battery, a comment like "still plenty of life left" sounds vague enough for me to think they didn't even check it.
    Sorry to sound skeptical, but if you can, post your tire PSI numbers here, and then we can go from there.
  12. gloriarifin
    san diego
    They gave me this result
  13. Elt31987
    Elt31987 Active Member
    205
    149
    Derry, NH
    Strange how low the voltage and CCA are.
  14. pianewman
    264
    183
    2018 Prius
    I don't like those battery numbers, either, but I'm no expert. If this was a "load" test, I don't think that voltage should dip below 12v.
    Hopefully, an electrical expert will post a response.
    (personally, I don't like the inconvenience of a failed 12V battery, and I always replace them proactively. In this case, I'd replace it now)
  15. gloriarifin
    san diego
    What is voltage test? When I was at the dealer I mentioned about the battery. And my service advisor told them to run battery test
  16. gloriarifin
    san diego
    Do you know what the number range supposed to be?
  17. Elt31987
    205
    149
    Derry, NH
    CCA should be as close to 295 CCA as possible or higher ( I know it doesn't matter for starting a Prius but could point towards a batteries health. As for Voltage, when your at 12V your battery is around 50 percent charged, so your around 45 percent or so. My battery will stay around 12.4V in between driving 2 times a week in quarantine
  18. gloriarifin
    san diego
    What should I do? Bring to the dealer?
  19. Elt31987
    205
    149
    Derry, NH
    Do you have a trickle/ float charger? And a multimeter
  20. gloriarifin
    san diego
    I could buy it if needed
