Mpg decreased
Discussion in 'Prime Fuel Economy & EV Range' started by Cook, Dec 16, 2017.
  1. Cook
    Cook New Member
    TN
    I’ve had my car over 2 years and have gotten 40-42 mpg until the past couple months. It has gone down to 36-38 mpg. The only change is I’ve been using my heater. I’ve tried buying my gas from different stations hoping for an improvement but nothing so far. I would appreciate any ideas?
  2. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    It’s the heater.
    iPhone ?
  3. fuzzy1
    10,259
    That is a reasonable decrease for winter. About where do you live, and how much decrease did you experience last winter?
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    this person is not driving a Prime so the heat comes from the ICE. And ICE is making heat whether you use the heater or not, so it's not the heater. check tire pressures
  5. fuzzy1
    10,259
    The ICE needs to make more heat in winter heating season, and that cuts MPG. The Prius doesn't make nearly as much 'wasted' heat as traditional cars, and spends significant time not making any heat at all. So cold weather and cabin heat have a greater impact when the engine needs to create heat to get up to, and stay at, operating temperature.
    But there are plenty of other winter reasons too:
    Why Mileage Gets Worse in the Winter | PriusChat
    priuscatprimeguy likes this.
  6. Ferrarilover
    185
    168
    Manchester, UK
    I agree. It’s the heater / need for heat.
    To be fair I think a drop from low 40s to high 30s when the weather gets cold is pretty good.
    iPhone ?
  7. bisco
    49,720
    check your tyres pressure, cold makes them drop. pump it up!:p
    fuzzy1 and priuscatprimeguy like this.
  8. Cook
    Cook New Member
    TN
    Thanks for replying. I’ll check my back records to compare. I thought of the tire pressure today too! Merry Christmas!
  9. inferno
    inferno Senior Member
    1,072
    405
    I've actually found a great strategy here and it's proven to work.
    When the engine turns on or when you go up a hill, blast the heat to get warm. When you're ready to coast or go into EV mode, turn off the climate and then turn on EV mode. My drop in efficiency is now around 25-30% versus 70-100%
  10. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    In any forum like this, it is always a good idea to search for previous threads about the subject BEFORE posting a question for the thousandth time.
    It's been covered before. MANY times. It is not unique to any one model.
