mpg drop after 3rd -15000km service
Discussion in 'Gen 3 Prius Fuel Economy' started by armuwaffaque, Nov 23, 2015.
  1. armuwaffaque
    armuwaffaque Junior Member
    25
    sri lanka
    hi all,
    I got the below readings while driving in the ECO mode only (without pushing the EV button)
    after the service when i break and re accelerate smoothly and softly from around around 15 kmph the real time mileage meter shows just 2 bars and then only goes up (in ECO mode and not ECO +EV combine)...
    and during the EV + ECO changes to ECO only while slight accelerations (not heavy) the meter dropps to 10kmpl and the only picks up very slowly...before the service while doing so it was dropping around 15-20 kmpl..
    they said they hv done a synthetic oil upgrade..
    my 215 45 r17 tyres pressure is Front 36 rear 34..
    when i go to the dealer again what should i ask them to check for (they'd know but to insisit)
    tkank you
  2. Mendel Leisk
    38,876
    Maybe they used a thicker oil? And/or dropped your tire pressures?
    armuwaffaque likes this.
  3. armuwaffaque
    25
    sri lanka
    thank you mendel...need to question about the viscosity of the oil they used...But the before service tyre pressure was (34 F 32 R) lower than the pressure i have set now (36F 34R)...so i assume its not caused by a pressure issue...
  4. armuwaffaque
    25
    sri lanka
    a small clarification please
    while driving in 60 kmph or so I took off my feet , changed the transmission to N position and felt a resistance (which was in the D mode)has disapeared and the car moved freely in N (so the parking breaks are not over tightened ...are they?.)...then i changed to D in the same speed...the next moment I changed to D I felt a big resistance...something like 1/2 of the B position...
    is it normal to have so... I mean to have a resistance while from N to D that can be felt readily.....??
    sorry for being such an amateur....
  5. Mendel Leisk
    38,876
    Switching from Neutral to Drive you will feel an increase in resistance. And see a little regen displaying.
    It seems like your parking brake is ok, if it feels freewheeling in Neutral. You could double check by feeling the temperature of all wheels right after a drive. If any brake is dragging, it'd feel much warmer than the others. Slightly warm for all is ok.
    I'm still betting it's a heavier oil grade.
  6. armuwaffaque
    25
    sri lanka
    thank you mendel....that was very helpful.....gonna talk to the lube guys morrow and will cosult U with the oil detail...
  7. armuwaffaque
    25
    sri lanka
    hello mendel...
    Went to the lube station a while ago..
    during the lube they did a mineral to synthetic oil (caltex) upgrade.....and the tech advisor said the grade of the synthetic oil they upgraded was 0W-20 (which is same as the previous mineral oil grade )...
    will it make such a difference?
    yet they are clueless about my complain....
  8. Mendel Leisk
    38,876
    I'm not sure there is any 0W-20 that is non-synthetic. And 0W-20 is the thinnest oil readily available, and the specified oil for Prius. Either they've done something else, say parking brake cable as you were wondering, or they're lying about the oil grade.
    Oh: or they grossly overfilled the oil? did you check that? It's not that easy, I believe due to convoluted tube the dipstick is guided through.
    Other than that I'm stumped, but if you're noticing the car being less free-rolling, right after the service, there would seem to be a connection.
  9. armuwaffaque
    25
    sri lanka
    thank you again for the concern
    he said the amount was 4.0 litres...they also did a an oil filter change....if they are lying, going again to them is useless and idiotic i guess.......atm am getting a series of readings and manual calculations to get an actual overall best mpg I can get.....I will keep posted.....could you please suggest an oil (brand) and the exact amount in litres that has to be poured (with the filter) so that i can go for that the next time or if the low mpg annoys me...
    thank you again..
  10. Mendel Leisk
    38,876
    I'm always using Toyota brand 0w-20, 4.2 liters with filter change.
  11. armuwaffaque
    25
    sri lanka
    thank you..... your info throughout the thread was very informative
  12. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    I use mobil 1 0w-20 , the one for hybrids is the green cap one. and use. quality mobil1 filter. I change oil every 12k..
  13. bisco
    49,695
    welcome! 12k? that's a new take. but i see you live on the wild side.:p
  14. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    I've been doing that with the mobil1 green 0w-20 for the past 40k miles..
  15. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    no issues.. mobil1 guarantees till 15k , around 12k you feel the car feeling heavy or dragging.. I get it changed.. the green hybrid formula is the best fluidity..
  16. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    1476665659213.jpg Here is my daily uber milage runs .. get gas milage , I have a person with oem A20 getting swapped tomorrow.
  17. bisco
    49,695
    very interesting, thank you. how many miles do you plan on keeping the car?
  18. Phatlife
    Phatlife Member
    107
    27
    New Jersey
  19. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    I put about 35k miles per year.. I'm at over 43k now.. the oil used by dealer is a mixed synthetic and regular oil and they use a $4 paper filter. no thanks. after mobil1 hybrid formula, there in no going back to any other oil.
  20. bisco
    49,695
    would uber be considered 'severe duty'?
