MPG Drop after EGR Clear
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by d4vit, Sep 13, 2023.
  1. d4vit
    d4vit New Member
    GE
    Hello,
    i have this kind of problem on my Toyota Prius Gen 3 (2013) and i hope someone from this forum can help me because i've tried everything.
    My MPG got dropped by half when i had 40 mpg stable i did EGR/Throttle/Intake clear and my MPG dropped to 20-25 after that i have no errors no faults
    Heres things which i've done:
    • I've changed spark plugs
    • i've change air filter
    • i've checked battery's in service all are good
    • i've checked Upstream(Oxygen Sensor 1) and downstream (Oxygen Sensor 2 after cat.) live data on scan tool all is smooth and fine , perfect air/fuel ratio
    • i've changed engine oil
    • i've checked all wheels pressures
    but still no big change i only feel some little change when i start to drive without A/C but before EGR clear i was using A/C same as after EGR Clear but i had good MPG
    Magic Mark likes this.
  2. Magic Mark
    Magic Mark New Member
    I'm wondering if a gasket is leaking on one of the components you cleaned? I'm trying to think of a hose that might not have been missed or something that wouldn't throw a code.
    Danno5060 likes this.
  3. JC91006
    16,482
    8,400
    That is a drastic drop in MPG. What type of plugs did you put in? Ones you bought from the dealer and not ebay right?
  4. d4vit
    d4vit New Member
    GE
    Yes but as i said i did spark changes after mpg drop after egr service before all worked like a clock
  5. d4vit
    d4vit New Member
    GE
    I also thinked that egr got dead but i should get at least fault code on diagnostic but i dont get it and tbh that is the only one thing which i didnt checked but i think i would get some changes or noice or error code but no all is clean
  6. d4vit
    d4vit New Member
    GE
    so no one can help me on so big forum? :(
  7. Mendel Leisk
    38,726
    Where’s “GE”? Are you in the United States of America? Or? Are there Toyota Dealerships nearby?
  8. d4vit
    d4vit New Member
    GE
    i'ts country Georgia we dont have official Dealership of toyota here
  9. JC91006
    16,482
    8,400
    I would suspect your brakes are somehow involved in the lowered MPG. It could be possible your brakes slide pins are stuck (possibly due to lack of lubrication) or your calipers are no releasing the brake pads.
    Weak batteries or engine issues would not account for that drastic of mpg drop
  10. Mendel Leisk
    38,726
    What’s the miles (or kilometres)?
  11. Mr. F
    Mr. F Active Member
    367
    216
    Washington
    Is the 20-25 MPG reading over a short drive or over a longer period of time? Any misfires at all?
  12. d4vit
    d4vit New Member
    GE
    no missfires at all, cant go more than 40 MPG i have range in between 35-40 MPG with long drive
    measured compressions in cylinders and i have 12.5 Bar in each im thinking it can be Spark plugs, but i receive 0 obd code
  13. TheLastMojojomo
    TheLastMojojomo Active Member
    231
    162
    US
    @d4vit Did you Disconnect your 12v Battery before doing the EGR Cleaning?
  14. Mendel Leisk
    38,726
    Again, what’s the miles?
