mpg dropping a lot
Discussion in 'Gen 3 Prius Fuel Economy' started by tdubb, Nov 11, 2012.
  1. tdubb
    tdubb New Member
    my mpg has dropped over he pas 2 weks from usually 56-58mpg o 47mpg now. why is that???
    the temperature outside is about 15-20 degrees cooler
  2. Adam Leibovitch
    498
    102
    In colder temperatures the ICE will be engaged more for longer, because it takes longer to warm up, and uses gas in the warm up process. It also cools down from warm state more quickly, requiring warming to happen more often.
    51,140
    and if you use the heat, it will run even more. also more tire and air friction in cooler weather and they might have switched to winter blend gas which costs you about 10% in mpg's.
  4. Mendel Leisk
    40,574
    The more you can avoid short trips, consolidate chores, the better. The short trips with engine heating up are just harder on mileage.
