MPG drops then resumes
Discussion in 'Gen 3 Prius Fuel Economy' started by Sarp1028, Feb 14, 2021.
Tags:
  1. Sarp1028
    Sarp1028 Junior Member
    55
    Atlanta
    I was on vacation for all of December and logged zero miles. When I returned, my car started right up. It sounded a little rickety and the check engine light came on. After two days of driving, the light went off. However, the MPGs dropped from my lifetime average of 42 to barely 30... a 25% drop. I spent the last month scanning the forums and reading conversation threads on topics that could be related to me without starting ANOTHER redundant topic.
    While many traditional solutions are frequently presented... there was a curious outcome amongst the MPG problems... the problem magically went away.
    This just happened to me this week. I’m back to 40-45 with casual, non NASCAR, driving. The most immediate thing I did before this realization is that I cycled the driving modes from eco, to off, and turned eco back on. No clue if it’s the solution
    I was prepared to clean my EGR system, go to 0-16 oil, question my tire change choice (non LRR), and change my aging but perfectly fine 12V. I did however buy a bluetooth OBD to check traction battery life. It’s about time to anyways.
    I just wanted to contribute my observation after spending hours reading all of the contributions the helpful faithful have provided on priuschat.
    2010 Prius III
    185k miles
    Second owner @ 96k miles
    Original traction battery
    Oil change every 10k with Amazon 0-20
    Trans fluid changed at 150k miles.
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    How old was the gasoline in the tank, from beginning vacation to putting icE back in use?
  3. Sarp1028
    55
    Atlanta
  4. Sarp1028
    55
    Atlanta
    One month.
    During the month of January, I was fueling up every three gallons, with worsening to static results. I ruled out Lupus too.
  5. bisco
    52,393
    who knows what happens to a car when it sits for a long time? maybe the computers get confused
  6. Sarp1028
    55
    Atlanta
    I am leaning toward a vague answer much like this. I believe there is something happening behind the scenes regarding the computer compensating for a variety of sensor inputs or lack of sensor inputs. I believe this is the answer for many of these "sudden" drops in MPG. The weather here dropped precipitously which correlated with the drop in my MPG. December through January maintained temperatures below 0*C.
  7. Sarp1028
    55
    Atlanta
    PS. Trying to keep my footprint on the forum low so ill freeload off my thread. If anyone has any insight into buying a replacement 3rd GEN traction/HV battery in continental Europe, let me know. Double points for install services. I have not found any information in the forums on resourcing a battery in any of the recent-years threads.
  8. bisco
    52,393
    i imagine it takes some energy to replenish a 12v that has been sitting a month
  9. bisco
    52,393
    i thought the warranty was perpetual in europe if you have it serviced every year
    SFO likes this.
  10. Sarp1028
    55
    Atlanta
    I brought it from the states but that’s an awesome fact
  11. bisco
    52,393
    i think you should start a new thread with 'need new hybrid battery in belgium' or some such.
    Sarp1028 likes this.
  12. Sarp1028
    55
    Atlanta
    That’s a great point too. Only when the MPG was back did I bother to hook up the multimeter: 12.6 cold / 14.7 with engine on. Many love swapping out their batteries preemptively but I’m a drive it until it dies kinda guy on the 12v.
  13. bisco
    52,393
    i did that exactly. 8 years, 3 months, had to call triple a.
  14. Sarp1028
    55
    Atlanta
    Yeah my battery is approaching the same with nearly 7 years.
  15. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    I was reading your original posts and really wondering why you were using MPG and gallons but live in Belgium. Why/how did you import a Prius all the way across the ocean and not just buy one locally?
  16. Sarp1028
    55
    Atlanta
  17. Sarp1028
    55
    Atlanta
    I wanted to have my car and the shipping cost was reasonable.
  18. Rocky Mountain Priusman
    224
    112
    Makes sense! Was it hard to get it inspected, imported, and registered, or do they let you continue to use US plates?
  19. Mendel Leisk
    41,909
    Get on the Exhaust Gas Recirculation cleaning ASAP; it’s overdue, by at least 85K.
    more info:
    Bad Flywheel | PriusChat
