"MPG from Start" - screen
Discussion in 'Gen 3 Prius Audio and Electronics' started by timpeti, Oct 6, 2014.
  1. timpeti
    timpeti New Member
    I was recently driving a 2013 Prius C and I was surprised to see that it had a screen indicating MPG from Start, Procent in EV mode etc. I'm wondering if there is a "MPG from Start" screen anywhere on a Gen. III Prius.
    Timpeti
  2. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    When you turn off the Prius, the display shows the mpg from the last time it was started. It only stays on for a short time though before the display turns off.
  3. timpeti
    timpeti New Member
    Yes, but I'd like to have access to this data during the ride. For me, this is the most useful data but I can't access it while driving. Very frustrating...
  4. Mendel Leisk
    38,743
    ScanGuage II works that way. You can show realtime mpg and accumulating since start up. Very handy. If you do a regular run, the accumulating will typically start out showing poor mpg, gradually improving. By the end of the trip you should be in familiar mpg territory. If it varies, maybe something is up. Culprits can be winter gas, snow tires, ambient temps, rain, AC use, more passengers/cargo, and so on.
  5. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    The easiest/cheapest way to do that then is to simply use 1 of the 2 trip meters and watch the CONS display. Simply reset A or B each time you want to watch the mpg for a particular drive. I only track mpg between fill-ups and can get a pretty good idea how I'm doing on a particular segment simply by watching the mpg go up and down, but I can see where it might be useful to check more closely when comparing routes, etc. It might be a bit of a hassle having to remember to reset the trip meter each time, but it's a lot cheaper than buying a ScanGuage just for that and I don't know if you can just leave it plugged in all the time.
  6. bisco
    49,513
    it would be sweet to have a lot more info screens available on the gen IV.
  7. timpeti
    timpeti New Member
    I use the trip meter for A: from tank to tank and B: from oil change to oil change, resetting it every time I go on a trip would mess this up. It's strange, some things are too abstract and technical (e.g. the unit of regenerated energy being Wh - why not oz of gasoline or -assuming average MPG- miles) while others fall short.
  8. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Somehow I knew you were going to say that :), so I guess a ScanGauge might be in your future.
