MPG hit for out of alignment?
Discussion in 'Gen 2 Prius Fuel Economy' started by problemchild, Apr 28, 2008.
  1. problemchild
    problemchild New Member
    429
    37
    I tried doing a search but 600 pages come up for mpg. My prius has been out of alignment from the factory. I just have not had time to bring it back in. Whats the hit on the mpg for this?
  2. bwilson4web
    16,010
    There is no easy answer since it is a function of which type, toe or camber, and how much. Also, tire pressure can mitigate some of the problem.
    I would recommend getting one of those IR temperature gauges and measuring the tire temperature across the treads after driving say 15 minutes at highway speeds. You'll have to stop quickly to take the measurements since they cool off quickly.
    GOOD LUCK!
  3. problemchild
    429
    37
    Ummmm
    I think I will just go get it aligned.
    Anyone know what kind of hit for an alignment issue? 3-5 aprox?
  4. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    ummmmm, good idea, get it aligned, dont worry about mileage hit, worry more about hit from premature tire replacement and possible other suspension wear
  5. problemchild
    429
    37
    All great topics OTHER then what I asked for.
    Never mind this question seems to be too difficult to answer.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Geez man, the first answer in the thread was the best you can expect. It depends upon any number of factors, none of which you've supplied.
    If you want random numbers just so you can chew on them then I'll give you some...more than 1mpg and less than 10mpg.
    Depends upon severity, depends upon speed, depends upon your base mpg, depends upon temp, depends upon type of alignment issue. Who cares what the exact number is for say 40mph at steady speed...whatever it is it's more important to have it corrected for handling, for tire wear and to improve your FE even if the number isn't great.
  7. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    I agree with efusco, Bob gave you the answer to your question.
    Why don't you just get the alignment done and let us know how much your mpg improves.
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Get the wheel alignment then after you use a few tanks you can let us know.
  9. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Your manufacturer's warranty including alignment is good for a year. Go to your dealer at the earliest possible time to have your alignment checked...the diagnosis should not cost you anything as well as if any adjustment is needed. Good Luck.
  10. bwilson4web
    16,010
    Hummmmm, I have been in deep thought about your question and after billions of nanoseconds have the answer. But you won't like it:
    42
    ps. In memory of Douglas Adams
  11. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Let me give a go at it . . .
    . . . Yep, 42 is as good an answer as any other. ;)
  12. sdmcgale
    sdmcgale Junior Member
    San Diego
    The rear toe was out on my '05 Prius, .34 on each side (spec is .02-.28 deg). The dealer had no fix for it, said to take it to an alignment shop. Alignment shop installed a shim kit. Mileage increased about 2mpg, from about 53 to 55mpg.
    The car also feels a lot more planted on the road now.
  13. sdmcgale
    San Diego
    P.S. WRT 42, it was Douglas Adams.
  14. Ichiro
    Ichiro Member
    335
    SF
