MPG huge fluctuations in the ODOMETER VIEW
Discussion in 'Prius c Fuel Economy' started by TarugoKing, May 17, 2016.
  1. TarugoKing
    TarugoKing New Member
    NJ USA
    2015 Prius c
    I have a 2015 PRIUS C for 3+ months now (used to drive a 2012 PRIUS) . Approx 3K+ miles traveled already to date. Anyway, I noticed on 2 occurence that my MPG on the odometer view has had a huge reading fluctuation. Prior to the first occurrence, my Travel A was somewhere around 46MPG and it closely matched the Odometer view reading. Then I noticed it go down to 33MPG while Travel A is still at 46MPG, both had the same miles traveled. I let it go and when I checked my MPG on the Odometer last week, it was back to normal.
    Then yesterday, it went down to 27MPG. Any ideas why this is happening? Never had that issue on my 2012 PRUIS.
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    The fuel economy that's shown for the three odometer views (total miles, trip A and trip B) is based on the distance traveled in each view. So if "Trip A" shows 10 miles, then the fuel economy that's shown there is based on your last 10 miles of driving. If "Trip B" shows 500 miles at the same time, then its fuel economy display is based on your last 500 miles of driving. When the odometer ("total miles since the car was new") is displayed, the fuel economy is based on the driving you've done since you started the car (i.e., pressed the "Start" button or turned the key to the "Start" position).
    The odometer display is always the shortest distance, so it's reading will always vary the most. Let's take an example: you start the car up and the last time you reset "Trip A" was 100 miles ago. So your "Trip A" display shows 100 miles and let's say your fuel economy shows 50mpg. You drive for a mile - the engine is still warming up and so it's not operating as efficiently as it normally does. After that first mile, your odometer display might show 25mpg, because it's entirely based on just that first mile. But if you look at the "Trip A" display, it will still be very close to 50mpg (maybe 49.8 or something...?) because it's based on 101km of driving, almost all of which was done at 50mpg.
    Then you hit a long downhill slope for 3 miles where the engine doesn't need to run at all. The fuel economy shown for the odometer view will go up to something like 75mpg because it's based on just 4 miles of driving, most of which didn't use any gas. But "Trip A" will still be very close to 50mpg because that first 100 miles at 50mpg is still a much bigger influence than the last 4 miles have been.
    So you'll always see the odometer fuel economy readings vary quite a lot more than the "Trip A" or "Trip B" readings unless you've reset "Trip A" or "Trip B" since you started the car.
  3. TarugoKing
    NJ USA
    2015 Prius c
    I thought the MPG in the Odometer view was based on the total mileage of the car from Day 1. As I stated, I have not seen my MPG had these huge fluctuations on my old PRIUS so it was odd to me. Anyway, I'll check on this premise and will report back on my observations.
    Thanks!
  4. Sean Nelson
    421
    182
    Nope, only based on how far you've driven since you started the car. That's why it says "from start" just above the MPG number.
  5. TarugoKing
    NJ USA
    2015 Prius c
    Yup I confirmed that. Now I know nothing is wrong with my P-C, thanks!
    My old prius had a similar view on the dashboard as the image below. It just shows ODO and the MPG. I've never seen the MPG go below 44 so I'm assuming now that the MPG is based on the total miles driven from Day 1. This is what I was expecting with the PRIUS C odometer view as well.
  6. Hambones
    Hambones Junior Member
    28
    Minneapolis, MN
    2014 Prius c
    What really gets my goat is that I left Trip A alone from day 1 when I bought my C new, so I would have that average MPG for the life of the car, then a couple months ago I had some warranty work done, they pulled the battery connections and it LOST IT ALL!!! That is pretty ridiculous Toyota, shame shame! Apparently they were incapable of saving that data to non-volatile memory, grrrrr.... oh well, I'll get over it, not much else I can do.
  7. bisco
    49,488
    yep, one of life's little detours...
