MPG is really good, but I want better...
Discussion in 'Gen 2 Prius Fuel Economy' started by BEATLZ, Apr 29, 2013.
  1. BEATLZ
    BEATLZ New Member
    I have been averaging close to or at 55mpg. I currently have "Low rolling resistance tires", K&N filter, and run full synthetic oil. What more can I do (cheaply) to get better mpg?
    CharliePrius likes this.
    52,012
    throw all the provisions overboard to lighten the weight.:p welcome to priuschat, all the best!(y)
    danboy, BCP and CharliePrius like this.
  3. CharliePrius
    CharliePrius New Member
    16
    I'm new to the Prius myself so i'm sure that others can offer more driving-style related suggestions, but i'm inclined to go with bisco ... if you're REALLY serious then cut some weight. Take out everything that doesn't have to be there.
    If your interest is a little more casual then turning your car into a rolling shell with just a driver's seat and a center console, i'd wait for someone else to pipe up. :)
    Best of luck on your mpg quest.
  4. fuzzy1
    10,494
    Go to CleanMPG.com and learn how to hypermile. Adjusting the nut behind the wheel will gain more than changing anything else.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Go on a diet.
    Every pound you lose, is a pound The Prius doesn't have to move.
    Seriously, there is a point IMO of diminishing returns.
    You're welcome to embrace any number of additions, subtractions and driving philosophies into action.
    But personally? What I would do would be happy with a 55 mpg average.
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I'd put the stock air cleaner back in.
    dorunron likes this.
  7. Ardentity
    Ardentity Junior Member
    CA
    Yah, I haven't had much luck with K&N air filters... With the same driving habits, MPG has pretty much remained the same. Only (negative) noticeable difference is increase in engine noise.
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    fuzzy1 revealed the secret to get the BEST MPG. "Learn to Hypermile". I can easily get 50+ just driving the Prius easily around town. But if I hypermile, the numbers definitely go higher.
    I am not a hypermile freak. In other words, I don't do it 100% of the time. However, I do it when it is practical, and advantageous.
    Also, for the OP if you have not pumped up your tires to max pressure yet give that a shot.
    FWIW, 55 is VERY good if that is your true average over several tank fulls. Good luck to you and welcome to Prius Chat.
    Ron
  9. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    My wife drives mostly around town the same way she drove the Explorer and gets 45-47mpg. I can drive it mostly longer distances on the highway, never over 55 mph, use the cruise, let off the accelerator long before the need, feather the brake when slowing to get more charge in the battery and I will get 55 mpg. My teachie son sees it as a competition, never goes over 50 and mostly 40-45, rarely uses the brake, and routinely gets 60-62 and has gotten 67mpg over 30 miles in the country. Driving style makes the biggest difference in mpg after the basics are in line. LRR tires, clean carb, good 12V battery, and all mechanicals functioning properly.
  10. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    congratulations on getting 55mpg early on. Some people move up fairly quickly climbing up the numbers, some people don't. I suggest reading through the Top 20 MPG record holders thread in the Gen III forum and you'll get lots of tips and links to hypermiling threads there. Or just search for hypermiling.
    Like what others suggested and in order of cost, i'd start with the free and easy modifications first. All it takes is time and commitment:
    1. raise tire pressures to 42/40 (that's what i use currently)
    2. more comfortable driving shoes (thin soled)
    3. learning how to read the MFD and understanding what exactly goes on in the HSD system.
    4. knowing the prius stages by heart.
    5. training your foot to be sensitive to pedal pressure and getting that muscle memory thing going.
    really important for gliding by feel, without looking at the MFD.
    6. learning and applying mild hypermiling techniques
    7. reduce unnecessary weight of car, driver, and passengers
    Improvements that involve some cash:
    8. grill block (in winter)
    9. proper maintenance (12v battery, oil, throttle body, plugs, alignment, brake adjustments)
    10. engine block heater (EBH) - a big help. I use it all year round
    11. LRR tires
    12. OBDII scanners like Torque / ScangaugeII (really helpful and a good investment)
    Other improvements that may help MPG a bit but will greatly improve road handling and feel.
    13. underchassis brace
    14. strut brace, under brace
    15. upgrade rear sway bar
    16. upgrade front sway bar
    17. lowering springs or coilovers
    Extreme aero mods to help MPG
    18. side mirror deletion
    19. wheel covers and fender covers
    20. kammback installation
    21. chassis smoothening
    best of luck on your quest! :)
    F8L likes this.
  11. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Warming up the ICE is hard on good FE. Short trips are out. In other words short hops and continual warm ups hurt your FE. So plan the use of your Prius. H
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
  13. BEATLZ
    BEATLZ New Member
    Lots of helpful tips! Overall I am VERY pleased with how this car runs, and the MPG I have achieved so far. The money it has saved me already is staggering! I currently put around 160-175 miles per day with my work commute. I have been a life long Honda guy and I felt like a traitor to the "H" badge, but I think I have been fully converted now after only a few months. Thank you all again for the tips! I will continue to strive for better and better MPG, but I don't think I am going to get too extreme with it. After all averaging 55mpg in a car rated to get 48mpg it pretty darn good.(y)
    dorunron and F8L like this.
  14. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Your car is probably OK, but a low rolling resistance car like a Prius is sensitive to proper alignment. If you get a chance, it might be a good idea to have it checked. If, that is, you are the curious type.
  15. MK500
    MK500 Member
    92
    San Francisco, CA
    2013 Prius Plug-in
    Make the wife/husband get out and push at lights so you have a rolling start.
    BCP likes this.
  16. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    My 2010 has 75,000 miles with Firestone non lrr tires. 140$ vs 400$. Great traction and braking! I drive it normally and achieve avg 46 in the summer and 43 in the winter.:):):) I've tried all of the Mileage tips and find it better (for me) to just drive it and enjoy a great engineered and a pleasure to drive little car:)
  17. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Oh, It also has to original 10 year old 12 volt batt.!
  18. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Want better MPG, remove all the seats, take off the spare tire for light weight.
  19. bisco
    52,012
    and the engine :whistle:
