MPG Issue and Sluggish
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brandon Ivan, Apr 30, 2017.
  1. Brandon Ivan
    Brandon Ivan New Member
    Austin, Texas
    Hello,
    I just test drove a 2010 Prius (with 90k miles) that I am thinking of purchasing. I noticed a few things and I'm wondering if they could be red flags with hybrid system or something else.
    1. Computer showed a trip of 10k miles that got 39 MPG. This pretty far below the average.
    2. Battery charge seemed seemed low, only two bars from bottom.
    3. The car seemed more sluggish in accelerating than the other 2010 Prius I drove. This was the feeling I had when briefly driving it in city and on highway.
    I'm wondering, are these symptoms related to hybrid battery or something else? Should I avoid buying this car?
    Thanks for any help!
    Brandon
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Avoid buying that car, if pressed avoid taking it for free.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    +1, might be signs of a bad hybrid battery. Could have been throwing codes, which an unscrupulous seller may have cleared.
  4. Brandon Ivan
    Austin, Texas
    I think you are joking, but I'm not sure.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If you are extraordinarily lucky, it is under warranty until 100,000 miles and you get a free battery. My bet is over $2000 for a battery. Bad luck and it is $3,500.
    Are you used to betting these amounts?
  6. Tariq87
    Tariq87 Member
    87
    28
    jordan
  7. fuzzy1
    10,602
    This could be an indication of the driving habits of the previous owner(s). Did you notice the average speed for those trip miles? If very high, then that MPG may be just fine, but the engine may have had a hard life.
    That could just indicate low speed city or parking lot driving (lots of EV with the ICE off) over the previous couple miles, or idling with A/C running. How well it comes back up to, and stays at, 6 bars on the highway or other conditions with the ICE (nearly) continuously running will be a better indication.
    Sluggish is a different matter, a healthy car should have felt just like the others.
  8. Brandon Ivan
    Austin, Texas
    Thanks for the replies. I don't remember the average speed, but it could have been highway miles. The driver did mention that he drives hard and sometimes uses "power mode." He tried to explain the low MPG as a result of his hard driving. But shouldn't the prius get better than 39 MPG even with "hard" driving.
    The car was sitting for a bit with AC on, then we took the car on highway for about 5 miles. The battery was at two bars after the short highway driving.
  9. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I'm with wat fuzzy1 says. Keep in mind that when the HV battery is depleted, the Prius will not use the electromotor a lot to support acceleration and it will feel sluggish. So don't drive it briefly, drive it for at least half an hour and see what the battery indicator does. It should be at 6 bars during normal (non-city) drive in 5-10 minutes and then the sluggishness should be gone.
  10. fuzzy1
    10,602
    MPG will depend on speed. Doesn't Texas now have some 85 mph highways? The Prius cannot get even 39 at that speed:
    Updated MPG vs MPH chart | PriusChat
    Tire choice and pressure (low) and driving style can bring it down even more.
    Do note that the average speed shown with the MPG and trip meter will read lower than actual highway speed, because it includes all the time spend at slow speeds, stopped at lights, and sitting in parking lots with ignition on.
    PWR mode is really just a user interface thing, not a real change to the powertrain, but would be suggestive of a driver who tends to drive hard. And that will be rough on cars in general.
    Before hitting the highway, that would be OK. But 5 miles on the highway should have brought it up well above two bars, so now suspicions are starting to rise.
    #10 fuzzy1, May 1, 2017
  11. Brandon Ivan
    Austin, Texas
    Do you know if a Toyota dealership would be able to run a diagnostic on the hybrid system that would reveal current issues? Is it worth messing with, or should I just move on to a different car?
    Data Daedalus likes this.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Toyota can read On Board Diagnostic codes, (OBDII) but if an unscrupulous seller just unhooks the 12 battery, they will be erased. If you manage about a 50 mile test drive overnight, you might have all the codes re-occur. You can't trust the codes if you don't trust the owner.
    Assuming the previous owner has been maintaining the car via a Toyota Dealer and you have the VIN, then you can get all Toyota service history here: Track Your Service Records with Your Toyota Owners Account
