MPG - mfd vs spreadsheet
Discussion in 'Gen 2 Prius Technical Discussion' started by sleonardelli, Jun 21, 2008.
  1. sleonardelli
    sleonardelli Junior Member
    141
    Ruskin Fl
    I have been tracking my 08 Touring mpg via spreadsheet since April. My question is actually in reference to the fuel bladder and mpg because I wonder if I'm filling my Pri enough to get an accurate measure of MPG on a spreadsheet. Today, for example, I filled at the same Sam's club I always do and filled 1 click (as I always do) beyond the auto-click. My MFD read 42.8 mpg but my spreadsheet indicates 48.2. Granted the spreadsheet doesn't always indicate better MPG. Considering the fuel bladder variables, how do I really know what my MPG is?
  2. richard schumacher
    7,682
    1,063
    United States
    The real MPGs are very nearly what's shown on the MFD. The system counts actuations of the fuel injectors, and so, unlike the manual method, does not depend on knowing exactly how much fuel is (or was) in the gas tank. The manual method applied to *one* fill-up can be very inaccurate in a Prius because there is no guarantee that the amount of gas you put in on this fillup is equal to the amount of gas burnt since the last fillup.
  3. sleonardelli
    141
    Ruskin Fl
    So, if my MFD indicates I need 5.7 gallons (I guess I'll need to carry a calculator) I should have filled to that point instead of the one extra click?
  4. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    How many tanks are you figuring your spreadsheet on? You can't draw conclusions from, say, just 2 or 3 tanks. The calculated number will become progressively more accurate with more tanks.
    Also, is your spreadsheet simply averaging MPG for each fillup or does it consider miles driven? In my spreadsheet I have a calculated column for "weighted difference", using this formula:
    =(F2*(C2/AVERAGE(C:C)))
    ... where column F is the difference between displayed and calculated MPG and column C is the miles per tank. I then average this calculated column for my cumulative difference.
  5. Fraser
    Fraser New Member
    667
    Navarre, Florida
    I just filled my third tank, and estimated how many gallons I should get based on dividing the MFD mpg into the miles driven on that tank. I came very close to that figure (8 gallons) when the pump clicked off. Added a soupcon of petrol lagniappe and off I went. The MFD and my hand calculator were just over 2 mpg apart. I check carefully the point at which the first pip comes off, so over time that will give me a pretty good idea of how many miles I'll get on that tank.
  6. richard schumacher
    7,682
    1,063
    United States
    That would work, assuming that the bladder would let you add that much. (Yes, it *seems* as though it should, but it may not always be possible.)
    But is it worth the bother? For a single tank, trust the MFD. For a long-term figure, the inaccuracy inherent in each individual fillup averages to zero and quickly becomes insignificant, so it's sufficient just to take the total miles and the total of the gas pump readings.
    Keep in mind that fuel pumps are not perfectly accurate either. By some strange coincidence they seem usually to be inaccurate in favor of the gas station owner, which makes manually-computed MPGs smaller than MFD MPGs.
  7. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Hopefully you now have had a couple more tanks of gas and can see there is variation in the amount of gasoline you can add to your car.
    Warning: Do not rely on the MFD to tell you how much gasoline you "should" be able to put in the tank. Take it to the automatic fill and one click beyond, and you should be OK. Even if you "know" the tank "should" take more, DON'T. Do a search on PriusChat to see the downside of overfilling the tank (and bladder).
    Also, do a search on MFD vs. MPG, and you'll see several long threads (some of which are very good) in which the differences and fluctuations are well-discussed and explained.
    Enjoy your new Prius!!
  8. sorthund
    sorthund New Member
    68
    Seattle, WA
    So should we still hit the reset button after refill.... (I haven't even filled my car yet?)...
  9. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    50 tank refills spreadsheet calculation: 50.72 mpg
    MFD.............................................. 51.6 mpg
    07 Prius
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Not bad. I assume the spreadsheet fuel data comes from the pump readings? For those doing manual calculations, keep in mind that gas pumps are not 100% accurate. Typically they are allowed some set amount of error. You can guess which way the error usually falls.
    Tom
  11. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    Yes, the spreadsheet fuel data was from the pump readings.
  12. richard schumacher
    7,682
    1,063
    United States
    It depends on what you want to see. If you want fresh MPG figures as you drive from that point, then yes. If you want the MFD to report net MPGs since the last time it was reset, then no.
  13. sleonardelli
    141
    Ruskin Fl
  14. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Hmm, not sure what you've done with that last column.
    Let's assume you have columns A through G there and your headings are in row 1. Replace what you have in cell G2 and below with a formula that figures the difference between columns E and F:
    [EDIT/CORRECTION]
    A big brain f**t here. Forget this:
    =F2-E2
    and use this, formatted as a percentage:
    =F2-E2/E2
    [EDIT COMPLETE :blush::der:]
    Now in cell H2 and below use my formula but change the reference to column F (where I figure the difference between the two methods) to column G:
    =(G2*(C2/AVERAGE(C:C)))
    Format that as a percentage. That gives a "weighted difference" for each tank, weighted by how many miles were driven. Finally in cell I2 use this, also formatted as a percentage, to figure the cumulative difference:
    =AVERAGE(H:H)
    I didn't take time to transpose your numbers and calculate a cumulative difference, but the tank-to-tank differences appear well within reason. Your last tank's difference is greater than the rest, but with the Prius' flexible fuel bladder you can expect that sometimes -- see my two April fillups below. That's why you can't rely on calculated MPG for just one tank; the more you have, the more accurate it becomes.
    To reassure you that you're in the ballpark with your tank-to-tank differences, here is my spreadsheet beginning last October when I first started tracking mine:
  15. sleonardelli
    141
    Ruskin Fl
    Okay, tried but it's not working. Tried rearranging columns and its not working. I thought I knew excel pretty well but am just getting frustrated. I'm wanna try to attach my spreadsheet so you can see my calculations but PC doesn't allow for .xls.
    BTW, started using your hypermiling technique (on YouTube) and have my highest MFD to date: 46!!!!!
  16. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Send me your e-mail by PM and I'll be glad to send you my file. And congrats on the results!
  17. bushface
    bushface Junior Member
    Spruce Pine NC
    the only MPG i trust is the life time mileage divided by total purchased. 8200 miles / 164.565 gallons = 49.8 MPG.
  18. mcsenerd
    mcsenerd New Member
    37
    Galveston, TX
    I second this notion...
  19. JimboK
    2,817
    190
    49
    Chesterfield, VA
    No question that's the most accurate method. But that won't help much for results from individual tanks, nor will it tell me how far off the MFD is from actual. That's why I use the spreadsheet. Now with several months' data, I trust the MFD's results to be within a 2-3% margin of error.
