MPG Readout
Discussion in 'Gen 3 Prius Main Forum' started by Azonie, Jun 5, 2014.
  1. Azonie
    Azonie Junior Member
    Have 2013 and wondering why the actual MPG is diff than readout?
    Pulled into gas station MPG readout showed 53.7MPG. But when I actually do the match I get 50.4MPG.
    Why would it be different.
    iPad ?
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    There's several threads here on this topic. Most of us accept that the reported mpg is optimistic by a few points.
    SCH-I535
  3. sopclod
    sopclod Junior Member
    I've found this to be true in other cars as well, it's not unique to the Prius.
    52,431
    i think it's because the speedo is faster than your actual speed so you won't speed.
  5. fuzzy1
    10,603
    Nope. The MPG is based on the odo, not the speedo. Odometers are not biased high, at these not anymore.
  6. Mendel Leisk
    41,957
    Doesn't excuse it. And it's by no means impossible to have a reasonably accurate mpg display: our second gen Civic Hybrid's mpg display was either spot-on or very slightly pessimistic. The only reason I can see for consistent, gross exaggeration reporting of fuel economy is..., well what do you think?
  7. BZzap!
    BZzap! Senior Member
    1,607
    878
    The EPA estimates are just that. Manufactures are required to report these estimates within a certain accuracy. There are, of coarse, upper and lower fudge factors that the EPA has to allow. Bear in mind the the reported fuel mileage figures that are published are huge for marketing strategies. So, if you are in the business of selling cars, wouldn't you take every advantage available to make your products shine in a brighter light ? Yes, indeed!
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    The OP is talking about the calculated mpg on the MFD vs. calculated mpg, not the EPA mpg estimates.
  9. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    The PRIUS Engine Control Module (ECM) uses an abacus instead of a computer to do it's "calculations" maybe? (wink,wink)
  10. Heat Gun
    Heat Gun Junior Member
    56
    Los Angeles, California
    But why computer always estimates 2-3 mpg more but not less? I would love to see 47 on computer but 50 with manual calculation? :)
  11. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Based on the many threads on this subject, the onboard MPG readout tends to be about 5% optimistic. As to the 'why" I have no idea, but I can't imagine it's a mistake or error given how consistent it is across cars. It's certainly to Toyota's benefit to have that onboard be optimistic since the vast majority of drivers trust it and don't bother to hand-calculate tank after tank to get a proper number.
    (Edited my typo, 5%, not 2%, is what I've observed as well)
    #12 Sporin, Jun 9, 2014
  12. Mendel Leisk
    41,957
    My dash-vs-calculated error is currently at 7.64%. That's with close to 43000 km's calculated.
  13. fuzzy1
    10,603
    When I traded it in, my 2010's error was similar -- 6.63% over 36k miles.
    I'm way behind on entering my 2012's fuel log into the spreadsheet, so don't have its current figure.
  14. 70AARCUDA
    845
    209
    Tucson, AZ
    So far (only 2,000 miles), our 2014 PriusĀ·4 has consistently been 5% optimistic at each & every tank fillup.
  15. KennyGS
    KennyGS Senior Member
    1,243
    1,045
    Keystone State
    I assume that none of us are really that upset. In the end, it's still a very nice number. So I have to ask...
    haole man and mtbiker53 like this.
  16. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Corrected my error, I meant to type 5%.
  17. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    It's doesn't actually "matter" but what's the harm in discussing it? :)
  18. 70AARCUDA
    845
    209
    Tucson, AZ
    ...and, what HARM would it cause *IF* Toyota simply "corrected" the algorithm to provide an ACCURATE value?
    Gas Mizer likes this.
  19. KennyGS
    1,243
    1,045
    Keystone State
    None at all. :LOL: That's why we're all here.
