MPG Update.....my new 2020 Prius
Discussion in 'Gen 4 Prius Fuel Economy' started by Billy56, May 4, 2020.
  1. Billy56
    Billy56 Member
    64
    58
    Seattle, WA
    2020 Prius
    L Eco
    As I mentioned in an earlier thread, I have a new "Sea Glass" color L Eco model. Am driving it daily, for many miles. Already have 42,000 on it after only 5 months! Mostly city, with some freeway cruises mixed in.
    I keep extremely detailed mpg records. For this post, I will state the indicated mpg.....I have accurately calculated the ACTUAL mpg to be 1.82 mpg less....based on GPS, ScanGauge, fuel receipts. Have been getting 720 miles per tank. The tank is too small, can never seem to put more than 9.4 gallons in it. Soon I am going to do my favorite test.....to see what the ACTUAL usable capacity is. Will bring small gas can with me, then run it out till I sense engine missing....then quickly turn it off with power button. I suspect that when RANGE says zero, there is still a lot of miles remaining.
    Here in the Seattle area, air temps are slowly going up, which greatly helps my numbers. I am a hypermiler since 1979, and a SERIOUS hypermiler since 2003.
    Currently I average 83.22 mpg. Am hoping to raise it to 86 when much warmer temps arrive.
    1) I NEVER use the A/C
    2) Change oil every 6500 miles using Mobil 1 0W-16
    3) Spend a LOT of time coasting in Neutral
    4) Try to stay OFF the brake pedal....seldom use the brakes
    5) Keep 51 lbs of tire pressure
    6) Always use ECO mode
    7) Look WAY ahead to the next stop light
    8) Generally drive slow, but not too slow to be annoying to others
    9) City drive speed limit or 2 mph less. Freeway drive 57 when max is 60.
    10) Am constantly thinking "MOMENTUM DRIVING" as my motto.
    Am having lots of fun....just wish the fuel tank was 5 gallons larger. After 42,000 the brake pads show almost no wear. Tires still are 7/32 tread. Maybe at 100,000 I will switch from the OEM Bridgestone Ecopia to Michelin Energy Saver. I seldom use B shift mode....only on a very steep downhill to help save the brakes.
    Tande and krmcg like this.
    49,488
    that pretty sweet (y)
    Billy56 likes this.
    49,488
    i wouldn't switch tires model, those bridgestone's are 'special'.
    when the range hits zero, you still have the reserve/safety left. see your o/m.
    49,488
    when i used gas, i used to get around 70 mpg using your techniques. shows how much improved the L eco is
    Billy56 likes this.
  5. krmcg
    2,592
    2,390
    Whittier, CA
    Renge = 0 will leave at least a full gallon of useable gas left in the tank. YMMV!
    I have added 11+ gallons of gas several times stopping at the first click.
    Billy56 and bisco like this.
  6. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Mine read 0 once a year and a half ago. Happened to be New Years Day, and the next three places where I could fill up were all closed. I travelled just over 50 miles after it went to 0.
  7. TinyTim
    TinyTim Active Member
    366
    224
    Seattle
    I have gone 50 miles past "0" on my trip computer. When I filled it up it was right around 9.9 gallons. I can't remember but I still had miles if I needed them.
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    42k miles in 5 months of ownership? You drive for Uber or Lyft?
    Some pointers:
    2. The OCI is 10k miles or 1 year. Why do you change it so early?
    3. Don't coast in neutral. You lose out on regenerative braking. Learn to pulse and glide.
    4. Braking actually increases regenerative braking. The pads and rotors will last the life of the car.
    5. 51lbs is quite high for pressure. If you hit a pothole, you can blow out your tires. Not good if you have low profiles. Low 40s/OEM spec is what most people run.
  9. George W
    George W Senior Member
    911
    511
    San Antonio
    I bet that other motorists get really annoyed with you. I try to do these things as well but when you are faced with getting rammed, Eco driving goes by the wayside.
    krmcg likes this.
  10. EChua5
    EChua5 Junior Member
    Double the mpg of my 2004 model. Amazing.
  11. Mendel Leisk
    38,726
    Good to use AC periodically. I know where you're coming from, but say at least once a month. And turn it off a mile or two from destination, set fan speed manually, let it run to exhaust accumulated moisture. It's good to run it, circulate oil in the system, verify it's working ok, etcetera.
    In winter, if you set the vent mode to heat/defog, it may be using stealth AC, even though the button's not lit. That's the way my 3rd gen was anyway: you could see compressor running with ScanGuage. Sometimes.
  12. TinyTim
    366
    224
    Seattle
    I was going to call BS on his post earlier but bit my tongue.
