MPG with & without AC... tested!
Discussion in 'Gen 3 Prius Fuel Economy' started by '10Prius, Aug 11, 2010.
  1. '10Prius
    '10Prius New Member
    29
    Charlotte
    Hello,
    I'm new to the Prius chat forums, but I've been reading the forum and learning for a while. Anyway, I noticed the effect of AC on fuel economy has been discussed off and on without much testing. Here are the results of a simple test I conducted. I drove a round trip loop that's a total of 20.3 miles long, twice (just over 40 miles). The loop was driven back to back in my 2010 prius II with 28,000 miles. The car was fully warmed up and I had 6 bars on the battery starting each time. The route has 8 stops total, and speed limit is 45 MPH. Pretty much steady cruising at 45 MPH with only gentle hills and almost no traffic (for consistancy). Outside temp was between 84 and 88 degrees F (temp varied along the route). AC was set to 78, except when the temp dropped I lowered the setting by 4 degrees to keep the same temperature differential. I drove gently (a nice Sunday drive), but I did NOT hypermile. First trip was with AC on. I got 59.3 MPG. Second trip was with the AC off and I got 67.9 MPG. An 8.6 MPG difference. FWIW, I have the Yokohama AS530's that reportedly cost 4-5 MPG vs. stock tires.
    Of course the AC may have very different effects on fuel economy depending on the type of driving, but at least we have a bit of a starting point now. :)
    Any thoughts?
    5 people like this.
  2. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    As long as you don't roll down your windows (increasing drag tenfold), then yes turning off your a/c will save gas. The less power being used, the more the hybrid battery stays charged. The more it stays charged, the less energy the ICE has to use to recharge it.
  3. '10Prius
    '10Prius New Member
    29
    Charlotte
    Understood. But if you read the threads about ac's effect on mpg the answers range from negligable, to 2-3 mpg, to a 10% loss. Here we have a resonably well documented loss of around 13% and almost 9 mpg!
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I would think you need to do that test about 10 more times to reduce any other influences.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    If he did it 4 or 5 more times and got consistent results I could put some faith in it. I doubt the results would be consistent though.
  6. '10Prius
    '10Prius New Member
    29
    Charlotte
    Well, I have no intention of doing it even 4 or 5 more times. Next time my wife is out of town on business I may do it again if the temps are mid 80's or higher. I'll share the results if it happens.
    FWIW, my 15 mile roundtrip commute to work typically nets 47-51 mpg with ac (usually 48'ish). It's stop and go traffic for all but the last mile. Without ac I typically get 56-57 mpg. There is more variation with this route because of differing traffic, so I consider it less scientific. It also includes ICE warm-up which would tend to make the figures appear closer than a fully warmed up trip would yield. Yet it shows a similiar difference in actuall mpg, but a larger percentage of difference. This route has been tested way more than 10 times in each configuration. YMMV.:)
    2 people like this.
  7. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    His results are consistant with my observations. Speeds above 55 MPH will have a 6-10% MPG drop depending on A/C demand and outside temp. City it's usually greater since your on battery alone at times. Nothing is free in a Prius, even electric A/C.
    Wayne
    2 people like this.
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I do appreciate the well done work you did and I realize we can't realistically expect statistically sound laboratory quality work here for free(well, except for Bob Wilson:cool: ). Thanks for the info and thanks for adding your work commute experience.:rockon:
  9. Colonel Ronson
    443
    33
    Tucson, AZ
    Hah, imagine the mileage drop if the A/C was belt driven instead of electric.
  10. '10Prius
    '10Prius New Member
    29
    Charlotte
    I agree about the belt. FWIW, I have an '03 Honda Civic Hybrid I just sold. I put around 90,000 miles on the car. I could hypermile some excellent economy out of that car (60 mpg+), but the A/C was a killer! My 52 mpg trips would become 38-39 mpg trips (41-43 mpg if I still enabled "auto stop"... no AC at stop lights though :eek:). A government study tracking hybrid battery performance (320,000 miles of data from two '03 HCH) put the mpg loss of the HCH at 13 mpg with AC use, which certainly mirrors my experience.
    Interestingly, the belt is always being pulled around the pulley, AC running or not, and turning the AC on still made a huge difference in economy. So while I expect the all electric AC is more efficient than a belt, I would guess the belt itself was a rather small percentage of energy loss. Every little bit helps though!
    More efficient or not, being able to shut the ICE off and have AC is worth it! ;)
  11. '10Prius
    '10Prius New Member
    29
    Charlotte
    Exactly! I chose the 45 mph route instead of interstate cruising because I guessed that overall drag would be near it's low point at 40-45 mph, which would (hopefully) let the AC energy consumption come through over the noise. I would imagine at 70-75 MPH the percentage of mpg loss and actual MPG loss would be even less (same rate of energy consumption for AC but a higher rate of speed, so the AC energy would be consumed over a larger number of miles...).
    In the city it gets confusing... it would depend on if you could do enough regen braking to power the AC or not. But my experience is that I take a bigger hit in the city. Though it's much less of a hit than my '03 HCH took!:D
  12. GBC_Texas_Prius
    218
    38
    gbc texas
    Converting to gallons used per hour would be a good way to normalized your experiment to compare with other's observations.
    As an example, lets say I can go 52 miles on a gallon of gasoline with the AC off. If I added in the gasoline the AC would use, what would my mileage be?
  13. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    A few questions
    1) What mode were you in? ECO mode will reduce the number of times the air conditioner compressor runs, to help MPG's.
    2) Was the car interior "cooled" to the starting 78F while you were warming up the engine?
    3) Were you running the fan (with no A/C) during your no AC run?
  14. bisco
    49,494
    i've never done a test, but i can beleieve these numbers. i usually see a 2-4 mpg drop per tank, but that's only with the a/c on part of the time. who drives a whole tank with the a/c? usually, you get a cooler day here and there and some evening or early morning trips.:)
  15. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    i drive the same route to work all year. Last year i did the same route, and i set my ac to 72 in the hot summer 90-100deg days. Then still driving the same route in the fall my mpg went up around 2 when i stopped using ac. So no big difference for me at all. To me it's not worth sweating in my car to save 20 miles a tank, or about 1$.
  16. '10Prius
    '10Prius New Member
    29
    Charlotte
    That's a good suggestion... I'll crunch the numbers tomorrow. My average speed for each trip was exactly 38 mph each time (per the trip computer). I was wanting to get a steady state gph figure for running the ac while idling anyway. It'll be interesting to compare the numbers.
  17. '10Prius
    '10Prius New Member
    29
    Charlotte
    1) Eco mode the whole time... eco mode is all I ever use.
    2) car was pre-cooled during ICE warm-up. Warm-up (and interior cool down) lasted about 20 minutes.
    3) No fan. Windows were cracked less than an inch to keep it tolerable. At 45 mph the drag would be of little concern. Fan would probably have been more efficient.
  18. Old Drum
    Old Drum New Member
    61
    Warrensburg, MO
    I'm not so much into hypermiling that I'm turning off the AC with temperatures between 95-100.
    For some reason today, on a trip of about 300 miles today, I'm having some of my best mpg's totals since I got the car in May. I'm just about ready to turn 7000 miles.
  19. '10Prius
    '10Prius New Member
    29
    Charlotte
    I don't suffer for better economy... unless I'm seeking data from time to time, if its uncomfortably warm, I run the ac. I bought a prius so I didn't have to suffer! I'm curious about the effect on mpg for comparison sake mostly.
  20. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    I set the temp of the a/c to 1/2 degree below outside temp, and use the lowest fan speed, blowing directly to my face. Don't set it to auto! This way, I feel cool enough and it affects FE minimally. My mpg always hover around 56-57 with or w/o a/c on.
