Featured MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by One4U2Envy, Dec 2, 2019.
  1. One4U2Envy
    One4U2Envy New Member
    Ky
    SINCE I have had my Prius 2010 Model my MPG has been at 44-45 City, 47-50 Hwy. Up until recently things have been really good then I had the new software update and I swear on the hwy I cant get over 38 MPG. I went back to the dealership and they told me nothing was wrong that I should drive in ECO mode more and so on. I have lost 70-80 MPG per each full tank of gas. Any advice on what the heck is going on?
  2. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    That’s a large difference!
    If it were a small difference in mpg, I would suggest you recheck your tire pressures. After each dealer service on our 2012, I noticed a drop in the mpg on our 2012 and finally tracked it down to the fact that they were deflating the tires from the 40 psi I had them at to about 34 psi, which seemed to decrease mpg by a small but noticeable amount.
  3. Mendel Leisk
    38,669
    Do you have any documentation, name/description of the update? I'm guessing it's the second update related to the inverter?
    We had that on our 2010 this spring, and I noticed "some" mpg drop thereafter. However, also put on new tires around the same time, and that's my number one suspect.
    TheeWood likes this.
    49,402
    welcome!
    if you search here for the update threads, you will find many similar complaints, but no solutions. not sure why
  5. Grit
    Grit Senior Member
    6,143
    4,056
    Wilkes Land
    It’s to keep ICE on longer and reduce inverter workload so it doesn’t overheat and die putting your life in danger on the highway when you are rear ended at 65 mph. Easy peasey.
  6. Grit
    Grit Senior Member
    6,143
    4,056
    Wilkes Land
    RMB likes this.
  7. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Look at it like what happened to the Insight GEN I. The design was over using the hybrid system/ battery and was later "detuned" to allow things to work longer. The result was a hit to mpg...same here.
    RMB likes this.
  8. bisco
    49,402
    i wonder if you drive like a granny, if it has any effect
  9. Mendel Leisk
    38,669
    That sounds plausible, and some have reported that, but personally I didn't. There were two inverter-related software updates right?
    I recall after the first one, a few owners were having serious mpg impact. But it apparently was due to poor TSB instruction from Toyota, the software update not applied properly/completely? @ChapmanF had some ideas on this.
    FWIW, I never noticed a mpg drop. If anything, it seemed like post-update the car had a slightly greater propensity to slip into electric-only, and accordingly mpg went up slightly.
    Now after the second update, I might have experience some mpg drop, a minor amount. I'm not sure, cus I put on new tires around the same time.
    Going back to our snow tires this fall, our mpg has improved lol. So I'm going to put most of the blame on tires. But I've got a hunch there was a slight cross-the-board drop in mpg due to the software. Maybe.
    We had an 06 Civic Hybrid, similar story as Insight I think, what a debacle.
  10. One4U2Envy
    Ky
    Yeah it was the second update. Did you have them check the inverter?
  11. Mendel Leisk
    38,669
    I just got the software update. I think it was all good, and my mpg drop is due to tires.
