MPGe Readout
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Nov 20, 2012.
  1. markabele
    5,084
    1,782
    Nebraska
    Maybe it's already on the PiP somewhere (non PiP owner here) but I've never heard anything about it if there is. Forgive me if it is.
    If not, how long before we see a MPGe readout on the PiP alongside a real world MPG readout? This would help hypermilers truly optimize how they drive I would think.
    52,393
    if that is combined gas and battery, then yes. there is no hv only unless you drive hv only.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you wanna point out where the MPGe readout is?
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you do know what MPGe is? right?
    Fuel
    Unit
    Btu/Unit
    KWH/Unit
    gasoline gallon 116,090 34.02
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Fuel​
    Unit​
    Btu/Unit​
    KWH/Unit​
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    There isn't one to my knowledge. The EV Driving Ratio screen has all the information to calculate MPGe (with charging loss assumption).
  7. bisco
    52,393
    i guess not. is it important?
  8. markabele
    5,084
    1,782
    Nebraska
    If you are referring to MPGe, then yes, I believe it is important. It is one of the only ways to differ between energy efficiencies of different vehicles and of course different energy sources.
  9. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    bisco,
    Its calculated for you on our PiP spreadsheet, far right side
  10. bisco
    52,393
    thanks track! now what do i do with it?:confused:
  11. bisco
    52,393
    so if i'm getting better than 50mpg, but less than 99mpge (pip epa rating?) does that mean i'm not going as far as i should on kwh?
  12. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    MPGe is just a way to calculate "miles-per-unit-of-energy", factoring in electricity and gasoline (sorry if thats technically incorrect, I'm no engineer and I do not read SAE papers for fun).
    Because the PiP can plug-in, MPG (miles-per-gallon of gas) is a bit of a meaningless metric, since you could get infinite MPG if you never used any gas. So MPGe is just a way to factor in the consumption of electricity too.
    Personally, I dont think MPGe means much other than to be able to compare it to other cars to see which car is more efficient in its consumption of energy (gasoline + electricity or just electricity alone). It seems when it comes to regular MPG, its YMMV.. but with MPGe, its YMMVG (your mileage may vary greatly).
    Looking at our spreadsheet, I dont see many folks getting into the 90s or more, even though the PiP is rated at 94 MPGe. However, if you look at our "group" average (at the top of the column), its 72.34 MPGe. If you go to Voltstats and look at the MPGe for the Volt owners, its somewhere around 60 MPGe.
    Lets just put it this way.. no one that has ever asked me about my car has ever asked me what MPGe I get. And even if they did, I wouldn't know unless I opened up the spreadsheet and looked at my own numbers.
    lensovet and dbcassidy like this.
  13. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    MPGe actually stands for "Miles Per Gallon equivalent". I don't read SAE papers for fun either, but Wikipedia has a good explanation for MPGe.
  14. bisco
    52,393
    so what would be the point of having a gauge in the car?
  15. John H
    John H Senior Member
    2,208
    558
    just like prius drivers that optimize their driving styles to achieve higher MPG numbers, they could learn and apply the optimum driving styles to maximize their MPGe.
    this might mean switching between EV/HV for segments of their commute, limiting their speed while in EV, changing strategy or drive route depending on temperature, etc...
    markabele likes this.
  16. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    The PC spreadhseet is a reasonable estimate for listed Pips as its based on both CS and CD measured usage.
    But note the 94 MPGe is for the Prius in EV mode, its 50MPGe in gas mode, and so the mix (using a harmonic mean) will generally be a mix. But just a some people beat the EPA on MPG, many can beat it on MPGe in EV mode.
    The voltstats data is not a reasonable MPGe estimate, its really just based on the EPA estimate for EV (95MPGe and the EV ration combined with the actual MPG combined using the EV ratio. My personal MPGe (which I track by hand using both gas and EV usage) is over 101MPGe, which is above what EPA lists as the EV MPGe. I'm way more efficient on EV than the EPA estimate (My EV only MPGe is about 125MPGe)
    MPGe or any other direct feedback on efficiency could help drivers figure how to be more efficient.
    The "slick graphics" that they seem to think some people want may be good for some. Others, like me, want quantitative data.
  17. John H
    2,208
    558
    voltstats has a rather simplistic method of reporting MPGe. It should not be used for comparison purposes, or anything really.
    my last 30 days ...
    1269 EV miles, 406kWh at the plug, 345kWh in the battery, 10.2 gallons equivalent. 124MPGe
    I have a regular morning drive of 21 miles that consumes 3.3kWh. I think that works out to 214MPGe :)
  18. drinnovation
    2,027
    586
    65
    CO
    214 is fantastic.. are you including losses from charging?
  19. John H
    2,208
    558
    No. My understanding is that MPGe should be tank to wheel rather than well to wheel. Should I ?
  20. drinnovation
    2,027
    586
    65
    CO
    EPA measurements use wall to wheel, so I do. Think of the wall as the pump.. and its Pump to wheel, not well. (We are not looking at efficency of power generation, just delivery from the wall-- what you have to pay for).
