MPGS Have Fallen from 48 to 39
Discussion in 'Gen 3 Prius Fuel Economy' started by ZBrink, Aug 9, 2015.
  1. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    I read this thread and the questions seemed counter productive so I will simply state some facts.
    My mileage has plummeted in the last few months from 47 or 48 mpgs per tank down to 38 or 39 mpgs per tank.
    This is a 2010 and I have owned it for 2 years. I have put 60k on the car in this time for a current total of around 97k. My driving location has been the same, my driving style has been the same (hard). I always drive in Eco mode and I use Shell 87 Octane about 80% of the time. The car has always been dealer serviced. In 2 years of ownership and all of those miles, I have consistently received 47 to 48 mpgs on average per tank until recently.
    Recent changes: New brakes, new tires (Michelin Premier A/S in factory size).
    I was involved in two accidents this year but the mileage was seemingly fine after the repairs. The car has been aligned twice in 2015 by the dealer.
    Where should I start?
    #1 ZBrink, Aug 9, 2015
    49,490
    oh boy. are the premier 'low rolling resistance'? if so, maybe they will need some break in.
    also the new brakes might be dragging. who did the work? did they do an alignment?
  3. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    The car was aligned after the tires and brakes. The new tires now have close to 5k on them.
  4. bwilson4web
    15,524
    We don't have ready access to your car to diagnose what is going on. But we have a few clues about what might be going on. Here is the milage questionnaire put together to establish a baseline so we might understand:
    Regardless, I'm interested in seeing two, 10 mile, benchmark runs, 10 miles each direction:
    1. Under 41 mph on cruise control - reset tripmeter after reaching speed
    2. Over 49 mph on cruise control - reset tripmeter after reaching speed
    The first one helps us understand if there is a problem with hybrid-mode operation. The second one tells us if there may be an engine issue. We'll compare it with this benchmark to understand the problem:
    Find fairly flat routes where you can run 10 miles, both directions at a fixed, cruise control managed speed. If there is a beltway (i.e., circular route,) perfect, one 10 mile loop will do it. Otherwise make two, 10 mile runs in opposite directions to take out elevation and wind effects. Average the two runs, a photo works great.
    Two things we've recently seen:
    • Excessive cabin heat - this can inhibit hybrid mode where the engine does not shutdown
    • Driving in "B" - useful descending tall hills, it also keeps the engine on all the time
    You mentioned two alignments. Any possibility of getting a copy of the last one posted here? The reason is sometimes the rear-wheels can be off from frame damage that wasn't corrected.
    An equally valuable source is to measure the tire wear if you have a say 5,000 miles on the new tires. If there is still an alignment problem, the tread-depth will vary. Typically this requires 4-5 measurements on each tire.
    #4 bwilson4web, Aug 10, 2015
  5. ETC(SS)
    6,555
    Always look where you've been.
    I'm presuming that you check your fuel efficiency manually, and tank-by-tank, and I'll take your word for the 7-8MPG change.
    1. Make sure that the tires are properly inflated and manually check your vehicle's gross alignment (let go of the steering wheel on the interstate and see if you get an immediate lane change.) Many people in this forum over inflate their tires, which is probably OK in this car as long as you don't exceed the maximum value on the sidewall of the tire.
    2. You're a little early for brakes in a Prius. The G3 has 4-wheel disc brakes. Drive the car 10 miles and feel your rotors. You might be dragging a foot. If one of the rotors feels excessively warm (like: you can't keep your finger pressed on the surface of the rotor) then you need to have your brakes double-checked.
    3. If the car has been dealer-serviced, that might mean a 10,000 mile oil change interval.
    Do you check the oil about every other fill-up? If not, you need to check now to determine if you have some premature engine wear. I'd also look at things like the PCV valve, MAFS, and the throttle body......and check to see if the engine air filter has been changed recently. These are low probability items, but they're easy to check and don't cost much if you do it yourself.
    Be careful mentioning "throttle body" to the dealer.
    That's like running can openers if you have pets in the house.....and for the same reason.
    Get back with us and let us know what's going on.
    I have a company car, and I don't think I can beat on it hard enough to make it get only 38MPG for a whole tank.
  6. bwilson4web
    15,524
    Uh, you can but it would make you sea sick unless you did a lot of surface time in small boats. <GRINS>
  7. ETC(SS)
    6,555
    LOL!
    Actually?
    I did.
    Quick tip:
    Never say "I don't get sea-sick."
    I watched a senior chief get green and barf into a trashcan (we called them something else) about an hour after he was bragging about never having gotten sea-sick in a 28 year career.
    We were in 40-foot seas and taking water down the bridge access hatch during a surface transit - and I got close to engaging in sympathetic sickness - which is different altogether than motion sickness.
    Since I have a lot of time in surface ships, I'm less prone to motion sickness, as in....it hasn't happened......YET.
    Submarines have a unique roll cycle (because they're shaped like cigars) and there's no external horizon to give your eyes a chance to clue your inner-ears into what all of the motion is about. Sharing atmosphere with 120 of your closest friends doesn't help, although most submariners are used to some of the more aromatic side effects of living in a sewer pipe with stern planes. Having been in the cargo hold of a few military transport aircraft, I would imagine that that's close to what you get albeit for a shorter time period, but most trash haulers are smart enough to fly over or around the kind of WX that threatens to make the wing tips touch----hurricane hunters and some patrol aircraft not being in that more intelligent grouping!!
    Bubbleheads are also notoriously prone to sea sickness since submarines spend much of their time below the wave action, where even a hurricane's fury is reduced to a gentle rolling action if you go deep enough.
    I beg the OP's pardon for chasing that squirrel.
    We now return you to our regularly scheduled mechanical mystery.....already in progress. :D
  8. bwilson4web
    15,524
    I once took a ride in a car driven by a former Naval aviator . . . who flipped between formation flying and intercept combat maneuvers . . . in rush hour traffic. Cinched that seat belt on tight!
  9. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    Hi Zbrink;
    I upgraded to Michelin premier A/S factory 17 inch tires and was having a hard time getting close to my summer MPG mark ... Until dealer noticed that I had uneven rear brake pads, indicating that one had stuck and wore the pad all the way down. After new pads and rotors (too much Syracuse winter road salt on rotors) I was back to expected summer MPGs. I even set a new fuelly record of 49.0 MPG. So check your brake pads and ease of wheele spin if you can.
  10. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    I'm wondering about a brake pad dragging too. I'm slammed at work this week but plan on getting back to this problem over the weekend.
    I'll be completely honest and say I've been lazy with this car. Normally I work a little on my cars but I have left everything up to the "pros". I'm just tired if paying their super high prices and I feel the service has been slipping.
    The pads were shot which is why I had them changed. The rotors were cheap enough so I had then replaced too.
    And I have seen a full 10 mpgs drop, not 7 to 8.
    These are great Bob, I'll try these tips this weekend.
    FYI I'm definitely not driving in B and I'm also wondering if there isn't some frame or suspension damage. The car does not pull to either side and the steering wheel is straight. However, something doesn't feel right and it's hard to describe. It's not a vibration, it's as if the front wheels are mildly fighting against each other yet the car still runs straight overall.
    #10 ZBrink, Aug 10, 2015
  11. ETC(SS)
    6,555
    One of the good things about rolling a Prius is that the car is pretty easy to maintain.
    Just lift the hood every now and again to make sure that you're not using oil------like every 1,000 miles.
    The Prius' oil sump is fairly small (<4q) and so running a quart low and changing the oil every 10,000 miles can be sorta bad for it.
    It's OK to be lazy and let the dealer attend to your car's maintenance needs, but don't let them BS you into thinking that they're the pros from Dover.
    Example: Brakes and rotors.
    Unless you drive like an idiot or you deliver the morning paper, you just shouldn't be blowing through brakes and rotors at 90K......and from your assertion that you've suddenly lost 10MPG (not 7-8!)....something is amiss.
    Sometimes, people in places like Bastan, New YAWK!, Houston, and anyplace on the left coast will blow through a set of pads in 90K, but it's kinda hard to maintain a 48MPG tank average and drive like a teenager who has aspirations to drive in NASCAR.
    As hard as it is to grind through a set of pads @ 90K, damaging a set of rotors while wearing the pads down to the chirpers and maintaining a 48MPG tank average is even harder.
    <sniff-sniff!!!>
    I smell........boat payment.
    And.....they might have screwed up the job to boot.
    Check their work.
  12. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    Please see the attached photos. I did both of the drives for 10 miles each with the cruise control set. Both runs were on the interstate and I kept a constant speed on relatively flat roads (It was not fun doing 37 mph in the right lane with my hazards on). I had all of the windows down and the sunroof wide open. The temperature outside was 82 and I had the A/C set at 71.
    I do drive the car hard and am in the DC metro area which is brutal on a car. All of the hard driving still gave me 47 to 48 mpgs with the exception of extreme winter cold. I'm may an amateur shade tree but I know enough to know the pads were very low. I saw them first hand as they came off the car.
    #12 ZBrink, Aug 11, 2015
    bwilson4web likes this.
  13. bwilson4web
    15,524
    Something with the car is wrong and I suspect it is rolling resistance because it shows up at 57 mph and 37 mph:
    • @57 mph - should be 60-65 MPG, not 48.8 MPG
    • @37 mph - should be 80-83 MPG, not 59.3 MPG
    I would start with a survey of the tire and brake temperatures. Then we need to see what is going on in the transmission. Something is eating your energy and the tell is 'heat.'
    Chazz8 likes this.
  14. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Ha-ha! Asking your car to cool the great outdoors to 71° explains a lot.
  15. chenderson2
    chenderson2 Member
    94
    57
    Houston
    I have a similar problem. My mpg has fallen from about 44 to between 35 and 38. This has happened before, but seemed to correct itself. This time I have been getting the lower mpg for 4 tanks of gasoline. We have been having temperatures in the upper 90's for several weeks and the dealer says that is why I am getting the low mileage.
    Are most of you also noticing lower mpg when the temperatures are high?
  16. bisco
    49,490
    sure, generally a few mpg's. but it's hotter where you are, and humidity really makes the a/c pump.
  17. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Have you recently started partaking in lunch hour autocross events?? :whistle:
  18. bwilson4web
    15,524
    Please repeat benchmark without air conditioner. My benchmark was without air conditioner.
    #18 bwilson4web, Aug 13, 2015
  19. chenderson2
    chenderson2 Member
    94
    57
    Houston
    Nope, no autocross events. In fact, I drive my cars quite gingerly. No jackrabbit starts or sharp braking. In the present weather, I'd say that the AC is probably on continuously. Anyone know how many mpg you lose due to the AC running all the time?
    It would be unbearable to drive without the AC in our Houston 100+ temperatures.
  20. Mendel Leisk
    38,726
    Rear brakes can be fine UNTIL they're disassembled for the first time. Putting them back together properly is tricky: the caliper piston has a four-spoke pattern that MUST be positioned so that the pin on back of inner brake pad is between the spokes. And it has to STAY that way.
    It's possible to even assemble it all correctly, and then before the brakes have decently "bedded" the piston may rotate, screwing things up.
    Raising the rear and turning the wheels by hand with parking brake off will confirm or dispel this possibility. A slight drag is ok, but if they're fighting, you have a problem there.
