MPH at which battery goes off & gas-only kicks in
Discussion in 'Generation 1 Prius Discussion' started by DCGreene, Feb 5, 2009.
  1. DCGreene
    DCGreene New Member
    Washington, DC
    A friend of mine says that at about 60 mph his Prius kicks into "gas only" mode (no battery use at all at this point). Can you tell me if you're aware of this mode and at what MPH you've experienced it? thanks very much
    DC Greene
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    Your friend should look at the Energy display on his car. Electric assistance works at any speed on a Prius. Look for yellow arrows from the motor to the wheels on the display.
    The 'normal' running mode for the car, at a steady speed on level ground, is the engine running with power going to recharge the battery. However, the system will periodically send some energy from the battery to the wheels, to prevent overcharging. If the battery gets into the green part of the display (seven or eight bars on the eight-bar charge indicator) the car will use more electric assist to discharge back down to six bars.
    The Prius mostly achieves its fuel economy through the Atkinson-cycle engine, which uses more of the energy available in the fuel (up to 36%, compared to a regular Otto-cycle petrol engine which gets around 20%). The battery has about enough capacity for a couple of miles of driving at 30mph.
    The engine shuts down and the car uses battery only ('golf cart mode') whenever the required total power to the wheels is less than the engine can supply efficiently, the battery's state of charge is sufficient (more than two bars), the engine is hot enough, and the speed is below 42mph. Above 42mph, the engine has to spin but is not necessarily providing power (this is to prevent one of the electric motors from over-revving).
  3. DCGreene
    DCGreene New Member
    Washington, DC
    Mike Dimmick - I greatly appreciate your thoughtful reply. Very helpful!!
    Marcia Greene
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    As an additional point, it's important to realize that power management in the Prius is complex and sophisticated. It changes by the sub-second, influenced by many variables. There is no magic "gas only" or "electric only" speed.
    Tom
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    FYI,
    Following chart is came from 2G Prius to understand how THS works.
    The site URL is...
    TOYOTA: Company > Technology
    It's written for the 2G Prius, but it's worth to read.
    Ken@Japan
