MSNBC Article: Tough hearings leave dents in Toyota’s image
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by joe1347, Feb 25, 2010.
  1. joe1347
    joe1347 Active Member
    669
    44
    AZ
    Yet more bad press for Toyota. I'm definitely not liking what's coming out in the hearings.
    Great!
    This just keeps getting better.
    I'm assuming by earlier version, they're referring to the Gen II that most of us drive. Great.
  2. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    There is a brake system drop-out that occurs under similar conditions as what happened with the Gen III Prius. The un-answered question is the severity of the drop-out (Toyota and its apologists insist it is a non-issue). There is also the absence of any brake-throttle override in the Gen II Prius. And apparently Toyota is not going to do any retrofit of a brake-throttle override either.
    Sounds like a middle-fingered wave from Toyota to me.
  3. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    As for the brake "drop-out," unless you automatically lift your foot off the brakes when they don't seem to be working, you probably shouldn't be driving. My Chevy Blazer does and my Cadillac did the same thing when applying the brakes rough/slick surfaces.
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    There is an override of the throttle when the brake is pressed in the Gen 2 Prius, demonstrated in this video by Carolyn of Luscious Garage.
  5. hill
    8,641
    Hope I won't get labeled an apologist for asking such a question ... but have you ever got on the freeway when there's very little traffic ... stomped the gas pedal to the floor ... and while holding it there, hit the brakes hard? .... much less in that scenerio, pressing the brake moderately?
  6. halfmoonray
    halfmoonray New Member
    74
    Wow that seems like a good video. It looks like when she came to a stop she took her foot off the brake while keeping the gas pedal depressed and was surprised/shocked by the "sudden" acceleration when she removed her foot off the brake.
    Is it possible that this is what is happening with the "brake issue" while driving over a wet puddle or train tracks: the person is not releasing the brake but the bumps/sliding over a puddle make the sensor detect that the driver has lifted a foot off the pedal just like in the video.
  7. halfmoonray
    74
    some drivers in a panic may do things they are not conscious of including something stupid like pressing both pedals down and then not remember what they did while testifying for congress or something
  8. dogfriend
    7,512
    1,189
    Carmichael, CA
    No, the "brake issue" is well understood - it is the transition from regenerative braking to friction braking which happens when one of the front wheels slips.
    http://techno-fandom.org/~hobbit/cars/storm.html
  9. dogfriend
    7,512
    1,189
    Carmichael, CA
    Apologist = Learning how the car responds to inputs and adjusting your actions accordingly.
  10. apriusfan
    6,050
    205
    S.F. Bay Area
    I tested the car approximately a half hour ago. Maybe my 2007 Touring edition has a defective brake-throttle override, but at present, the override does not work as it is supposed to. I repeated the test with my 2010 BMW 3 series and the override works as advertised on the 3er (the engine goes to idle and the brakes stop the car).
  11. apriusfan
    6,050
    205
    S.F. Bay Area
    I fixed your post.
  12. austingreen
    austingreen Senior Member
    13,635
    4,177
    Austin, TX, USA
    Apologists also have the problem of blaming owners for bad driving when they expect a car to work properely. Think a dealer is right for calling a driver with unintended acceleration is a lier, and not checking out the problem, because Toyota hasn't announced it is a problem. Since the driver was obviously using her car incorrectly, there was reason for toyota to go to arbitration with the facts so that they would not have to buy her car back (no problem hiding the facts of other cars doing the same thing) (see day one testimony). Have excuses for all 39 dead bodies suspected of unintended accelleration, and think the government is out to get Toyota for investigating. 39 for toyota versus 11 for all other companies combined must just be bad drivers buy toyotas.
  13. hitechboy
    hitechboy New Member
    128
    Toronto, Canada
    I wouldn't think so. I had tried many times to replicate the issue by suddenly lifted my foot off the brake pedal, the car didn't not feel like it accelerating. May be I was not fast enough.
  14. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    Yes, like the "victim" who said her car accelerated unexpectedly, she called her husband on the cell phone, was finally able to get the car stopped in the median of the freeway, but the car "was still going 30 miles per hour." Well which was it? Was she stopped or going 30 miles per hour? You know what they say about eyewitness testimony. :rolleyes:
  15. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I owned an 03 Civic Hybrid for almost 5 years before buying a Prius in 07 and the brakes acted the same way when a bump cut off regen and the friction brakes took over. Kinda took me by surprise the first couple of times. After that it was no big deal. When I got the Prius and it did the same thing, I just thought "this one does the same thing". Again, no big deal. Just keep your foot on the brake and stop the car.
  16. dogfriend
    7,512
    1,189
    Carmichael, CA
    You must have misunderstood my post, there was no reason to fix it.
    Why don't you sell your car? It is obviously defective. I will continue to drive mine without apology.
  17. hitechboy
    128
    Toronto, Canada
    If Toyota offer to buy back from any concerned owner. Many of them will took the offer. After all, its only a car.
  18. apriusfan
    6,050
    205
    S.F. Bay Area
    And stiff the new owner with a defective car? Maybe that is your ethics, but not mine. I am keeping my options open for a repurchase by Toyota. Safety issues are treated differently than convenience items (window motor failures, for example). Fortunately, California is a bit more consumer-friendly than other states, so we shall see. Right now, I am off to the dealer to see how long it will take for them to check out the car. With all of the recall work being done, I wonder if I will be able to get an appointment in any reasonable time.
  19. joe1347
    669
    44
    AZ
    Yep, Toyota seems determined to convince every American to never buy another car from them.
    Of course, the way things are going, most of us will be driving Toyota's that are worth less than a used Pontiac Aztek with 100,000+ miles that burns a quart of oil with every fillup.
  20. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Why wait?
    I'll give you $1,500 right now... :D
    Paypal?
