Mudflaps - what's the difference?
Discussion in 'Gen 2 Prius Main Forum' started by Zarzoo, Jun 13, 2006.
  1. Zarzoo
    Zarzoo New Member
    Orange County, CA
    I was just looking around on ebay to see if there were any interesting things to add on to my "soon-to-be" Prius, and noticed that the mudflaps on ebay are like half the price of the ones here in the PC Store. Can someone tell me what the difference between these two are? I don't mind spending more money if the mudflaps here in the PC Store are alot / much better, but it seems like they are the same.
    TOYOTA PRIUS MUDGUARDS MUD FLAPS 2004 - 2006 MUDGUARD
    And, BTW, do these mudflaps seem to help much, or are they mostly for looks?
    Thanks in advance,
    Nick
  2. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Zarzoo @ Jun 12 2006, 09:50 PM) [snapback]270378[/snapback]</div>
    I can tell you several factual things, and you can make your own decision:
    1. Deland Toyota has treated me very well in the past.
    2. I try to buy things that will help support Prius Chat as often as I reasonably can.
    3. The flaps are all the same.
    4. They are functional, and recommended by just about everybody who has installed them. Including me.
    5. $36 is still quite a bit more than half of $54 when delivery is included.
    http://www.darelldd.com/ev/prius_splash_guards.htm
  3. Zarzoo
    Zarzoo New Member
    Orange County, CA
    <div class='quotetop'>QUOTE(darelldd @ Jun 13 2006, 12:00 AM) [snapback]270379[/snapback]</div>
    Thanks alot for the info Darell!
    I agree with supporting Prius Chat (I have already ordered the Front Heatshield Sunshade from PC, and I plan on getting the Shark Fin (probably next week after I pick up my vehicle)). I was mostly checking to see if it was the same product or not.
    Now I know, and knowing is half the battle. :)
    Nick
  4. mmmdowning
    mmmdowning Junior Member
    37
    Spotsylvania, VA
    I bought mine from Ebay, they are great and I saved some money. If I can save money on the same item I'm there. The money saved filled up the tank. Bought my Toyota factory oil filters there also. Just 3.49 a filter and bought 10. I'm not one to waste the little money we have.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(Zarzoo @ Jun 13 2006, 12:50 AM) [snapback]270378[/snapback]</div>
    I bought mine primarily hoping they will protect against rocks from the quarter mile gravel driveway I drive everyday, and secondarily as mud protection. So far, so good for the rock protection; no rock chips yet on the lower side body panels. For mud protection they seem to do OK. But then I try to avoid mud and wash the car weekly, so it doesn't usually get very dirty anyway. As a side benefit, I like the way they look.
    Be aware that if you install them yourself, you need to do a little drilling and the rear wheels have to come off (the front can be installed by turning the wheels). It's not difficult though.
    I thought I noticed a small hit on my highway fuel mileage after I added them, as described in this thread:
    http://priuschat.com/index.php?showtopic=18994&hl=
    Longer term experience suggests that the fuel mileage hit for me is minimal, if at all. I got 610 miles out of my last tankful, average 55 mpg, with a combination of city and highway driving. Nonetheless, I've made a small modification that allows me to easily remove them for long trips, when I'm most concerned about fuel economy and least concerned about my gravel driveway. The mounting hardware they come with includes Phillips head sheet metal screws. The reason you have to remove the rear wheel is that there is not enough clearance to use a screw driver. I replaced the stock screws with hex head screws that are easily accessed with a box end or open end wrench, without turning the front wheels or removing the rear ones. I keep a box end ratchet in the car just for this purpose, so now I can completely remove them or replace them in about 10 minutes. One minor aesthetic issue with the replacement screws: they are stainless steel and more noticeable compared to the black stock screws. I've thought about buying some black paint, but the appearance hasn't bothered me enough yet.
    Jim
  6. Rest
    Rest Active Member
    1,210
    53
    CA
    Since when are "mudflaps" (splash guards), only for looks? They serve a purpose, which is to keep liquid and debri off a vehicles body, thrown up by the tires. If you notice most auto manufactures design vehicle bodies tappered under a bit. While this helps with aerodynamics, the tires are outside of this and will easily throw water and road debri up and onto the body. Not good for the paint or in keeping a car clean.
  7. jamarimutt
    jamarimutt New Member
    985
    My car has 49,000 miless without flaps. When I wash it, the rear quarter area still looks like new. The only practical use I can see for the flaps is protecting against tar, which comes out with a some tar remover. I think that the flaps detract from the clean lines of the car.
  8. onerpm
    onerpm New Member
    477
    MN
    before I had the flaps, the front wheels threw up a lot of mud, etc., onto the body. I didn't notice much of a problem with the rear.
  9. Tideland Prius
    16,158
    You might wanna jet the water inside the rear wheel well facing the rear about midway up. You'll see a lotta brown water come out of the hole in the rear skirt.
  10. pinball
    pinball New Member
    121
    Surrey UK
    I got mine from my local dealer.
    They fitted perfectly
    Took me 30 mins
    Didn't need to take any wheels off either
  11. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(jamarimutt @ Oct 25 2006, 02:36 AM) [snapback]337860[/snapback]</div>
    Must be nice to live where you do, where ever that is! No rain? No mud?
    Where I come from it rains a little and the flaps stopped mud from being thrown up on the front quarterpanels and doors.
  12. KK7PW
    KK7PW Junior Member
    Seattle
    Re: Mudflaps - what's the difference?
    Me too! I chose not to remove the rear wheels, and instead drilled the bottom screw hole on angle for an angled entry. I screwed in the supplied phillips head screw until it just lightly scored the plastic with the screw head. Is tight to the wheel well and should be fine.
    Btw, since install, I have driven through mud and gravel, and the flaps work (and look) great!
    Thanks to all for your comments. Prius chat rocks! :rockon:
    de KK7PW
