Mudflaps????
Discussion in 'Gen 2 Prius Accessories & Modifications' started by gblatt, Aug 6, 2005.
  1. gblatt
    gblatt New Member
    46
    Sterling, VA
    I've seen a couple of ads on ebay for genuine Toyota mudflaps. I guess they aren't available as an option here in the USA so my dealer can't get them. Anyway, how easy are they to install? Do I have to drill holes in the body to install them?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Very easy to install, worst part is removing the rear wheels for a few seconds. Yes, you have to drill a few holes in the plastic of the wheel wells...it's really not hard, not a big deal and just takes a few minutes.
  3. gblatt
    gblatt New Member
    46
    Sterling, VA
    Thanks. I was afraid I would have to drill into sheet metal to install them.
  4. RetiredProf
    RetiredProf New Member
    Buffalo, NY
  5. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    If I can do it, anyone can... I did.
  6. passthepumps
    passthepumps New Member
    Just a word of CAUTION with OEM pre-molded contoured mudflaps!! I installed similar mudflaps on a Surburan (recently traded for my Prius) last year while in upstate New York. The OEM type mudflaps typically install inside the wheel well with screws and/or plastic grommets and designed to have a 2" or so pre-molded overlap that lies onto the exterior painted metal surface of the wheel well. This overlap extends onto the "pristine" painted area around the wheel well. Dirt, grit, dust, small peebles, and general road debris will collect behind this overlap and scratch the paint. In reviewing all available "OEM" mudflaps I have yet to read any disclaimers about this issue. The road debris that collects behind the overlap will scratch your paint job unless they are installed very,very tightly to the "pristine" painted surface. If debris collects behind this type of mudflap the continuous friction created by vehicle motion,wind, and general driving will take its toll!! I have yet to see any of this type mudflap that fit "super" tight to the exterior painted surface to avoid the collection of debris. The possible solution to this issue is to install a 3M type clear painted protective sheet onto the exterior painted area where the abrasions will occur prior to installation of the OEM mudflap. Another solution may be to seek the "old style" flaps that just hangs from inside the wheel well. I would strongly suggest if you live in a "road debris" proned area check for the paint damage before it gets too bad. When I realized the damage on my then, brand new Surburan, it was too late. Thanks for the site and the future replies, if any!!!
  7. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    Would it be practical to run a bead of clear silicone sealant along the seam between the wheelwell and the flap?
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I have had the Canadian splash guards for almost 2 years and have never had this problem. They fit the body contour very well. Can't speak for those presently on eBay.
  9. efusco
    19,891
    1,192
    Nixa, MO
    I, too, have the Canadian one. They do get some grit in that seam...but not a lot. I guess there's a chance it could lead to some abrasion, but I don't intend to take off the flaps during the life of the car so it won't matter. Not worried about corrosion b/c the part is plastic that the flap is mounted to.
    Not something I'd waste time worrying about and I definately prefer less spray all over my car that the flaps provide. Not to mention that they look a LOT better than some cheapo dangly flap.
  10. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
    I installed the OEMs from Sigma Automotive and noticed that they don't stop all the spray. It's because of the car's aerodynamic design. There is practicly no fender flair so the flaps would have to extend up the fender another foot or so (which would look pretty lame) and stick out a few more inches. Oh well.
  11. passthepumps
    Hello Jack06, silicone sealant may very well be an option. Applying that product is somewhat of an art and carefully done it would never show. I imagine if I had the contoured flaps already installed I would clean the area well and spray behind the flaps (if they appear loose or receptive to road debris) and then apply the aforementioned sealant. Another option is to remove the flaps and clean behind them very well and assess any damage. My initial post was a matter of concern rather than alarm because I have personally seen the damage to a perfect paint job that this type of mudflap can do. Thanks!!
  12. slortz
    slortz New Member
    316
    Everytime I hear someone say "mudflaps," I think of the line out of one of Spinal Tap's songs. "Big bottom, big bottom! Talk about mudflaps, my girl's got 'em!" :lol: Great movie.
  13. jimklausner
    jimklausner Connecticut Yankee
    44
    New Milford, CT
    Has anyone bought/installed the mudflaps sold by MetroTpn? If so, what is your opinion of the product and of the installation procedure?
  14. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< Quote gblatt regarding MudGuards: "I guess they aren't available as an option here in the USA..."
    Actually, OEM MudGuards ARE available on the 2007 Touring Edition, Package 6, Extra Mile Option A - available in the 5-state Disbributer Region based in Houston Texas. It seems "packages" vary in other U.S. Regions, so I can't be sure about other areas.
    The Mudguards were accidentally omitted from my '07 Touring but ordered and installed by the Dealer, no cost to me.
  15. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(ConnecticutYankee @ Dec 12 2006, 02:13 PM) [snapback]361023[/snapback]</div>
    That's where I got mine.
    My main reason for buying them is to protect the sides of the car from the gravel on the 1/4 mile driveway I drive daily. So far, so good; no dings from rocks. And it seems to help with mud too.
    The installation was straightforward, though as others in this thread indicate, the rear wheels must be removed and some holes must be drilled for the rear. The drilling is easy. It's in the non-metallic part of the lower wheel well where the bumper cover material wraps around the side.
  16. jimklausner
    44
    New Milford, CT
    <div class='quotetop'>QUOTE(Charles Suitt @ Dec 12 2006, 02:24 PM) [snapback]361033[/snapback]</div>
    Thanks for the info. Mine is also a '07 Prius Touring, but I did not roder package 6. However, I am calling my dealer's parts department and body shop to ask about availability of mudguards.
    Again, thanks for the reply.
  17. livelychick
    livelychick Missin' My Prius
    1,085
    Central Virginia
    <div class='quotetop'>QUOTE(JimboK @ Dec 12 2006, 03:34 PM) [snapback]361087[/snapback]</div>
    And they look cool, too!
  18. JimboK
    2,817
    187
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(livelychick @ Dec 12 2006, 04:49 PM) [snapback]361146[/snapback]</div>
    Why, thank you! You must have seen my car at Chesterfield Town Center last week! :)
  19. jgills240
    jgills240 Member
    190
    Palmdale, CA
    I noticed that Corolla mudflaps are a bit cheaper than the Prius ones, almost $30 (depending on seller). I've also heard that the Prius uses a Corolla chassis. Wondering if anybody's put corolla mudflaps on their prius? or knows weather or not they'll fit. If not i'll just suck it up, but wanted to be sure. (couldn't find anything in other old threads.)
  20. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(jgills240 @ Feb 28 2007, 09:37 PM) [snapback]398216[/snapback]</div>
    I recommend Deland_Toyata on ebay. $39.99 and good service.
    TOYOTA PRIUS MUDGUARDS MUD FLAPS 2004 - 2007 MUDGUARD
