Multi Error Messages 2018 prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Resonate, Jan 11, 2026 at 11:45 AM.
  1. Resonate
    Resonate New Member
    Yesterday
    Usa
    2018 Prius
    2018 Toyota Prius One
    Malfunction of parking assist, lane departure, pre-collision, APGS, tire pressure, air conditioning, power windows. Only engine error code is lost communication with active grill shutter module.
    I'm hoping it might be a fuse but I've been unsuccessful at pulling the fuse. The little plastic fuse pullers at auto stores are to big.
    If it's not a fuse it's there any way you guys might suggest figuring out the issue myself. I don't really have the money for a big repair like the bcm and diagnostic right now.
    52,084
    any trouble codes with tech stream? you could run an ohm meter across the fuses for continuity. any of the cameras/sensors dirty?
  3. Resonate
    Resonate New Member
    Yesterday
    Usa
    2018 Prius
    I'm not sure about the tech stream or how I would check that . The sensors are/were dirty. But I did try to clean them. But would dirt sensors really cause all those systems to fail?
    52,084
    no idea, sometimes systems are integrated, sometimes not.
