MULTI-INFORMATION DISPLAY
Discussion in 'Prius v Main Forum' started by ANCHORMAN, Feb 20, 2020.
  1. ANCHORMAN
    ANCHORMAN Junior Member
    25
    Jacksonville Beach,Fl
    2015 Prius v wagon
    After a couple weeks experimenting with changing the display, I have not found an option to display any status if the motor is on the battery is in use or charging, etc. AI think a diagram pops up when I shut car off but not much use. Am I missing something? 2015 V model 4.
    51,155
    i'm not familiar, but my lift back has a button to the right that says 'car'
  3. lrisius
    lrisius Member
    121
    57
    Illinois
    2015 Prius v wagon
    My 2015 v level three has a mode where it display a nifty graphic of power movement. There is an engine, a generator, the battery and the front wheel. Arrows display showing where power is moving so if there the engine isn't running, there is no arrow from it. If it is running, there can be arrows from the engine to the generator and/or wheels. Arrows show flow into and out of the battery, etc. I don't recall off the top of my head how to get there, I just cycle through the right/left arrows on the steering wheel to get to it. These arrows take me through a rotation of nav info (direction, name of road), radio info, the display I am talking about etc. I don't recall if I had to do anything to get this set up- seems like it came set that way from the dealer. I don't tend to use it a lot because it can be a major cause of distracted driving. Seems like this would be in the manual somewhere. If my level 3 has it, it seems like a 4 should.
  4. ccaudio1
    ccaudio1 Member
    51
    37
    CA
    2013 Prius v wagon
    What they said.. have the same
