multi instrument display crack?
Discussion in 'Gen 2 Prius Main Forum' started by mark_hamrick, Aug 24, 2004.
  1. mark_hamrick
    mark_hamrick New Member
    103
    Littleton, Colorado
    If this has been covered, forgive the novice...is the vertical crack in the display plastic (not the screen, but the plastic covering the speedometer area) normal? In other words, is this a 2 piece part of plastic or should I be concerned that mine is defective?
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
  3. flyingprius
    flyingprius New Member
    152
    Daytona Beach, FL
    I know what you are referring to; that little crack seems a little low quality or abnormal for a Prius, but you have nothing wrong. That's totally normal. Enjoy your Prius :D
  4. mark_hamrick
    103
    Littleton, Colorado
    Thanks much! Now I can relax knowing my baby isnt damaged so soon after birth! :roll:
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I didn’t even notice it so I had to go check it out. Yep two pieces. Wonder why? Why not one piece. Must be an assembly line issue.
  6. Tempus
    1,690
    Washington DC
    I figured it was just an 'expansion joint' like in concrete. With the temperature changes a dash undergoes in sun and such, a long rigid piece of plastic could break easily.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I would think that you could provide for that on the edges. As an old (very) assembly line worker I still think it is a ease of assembly issue. FWIW
  8. exces6
    exces6 New Member
    97
    Houston, TX
    Maybe they'll fix it in the 05's.
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    when it was really hot it was almost closed, in the 90'sF by hot. I noticed it in November of last year. and it was a lot wider than in August
  10. InTheWASide
    InTheWASide New Member
    252
    Everett, WA
    I can not figure for the life of me what you all are talking about. Printed this page and looked in my car... Can someone please take a pic and post it?
    I'm just not seeing it :crazyeyes:
  11. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I'm with Brad. I looked last night and got nothing. Please post a picture just so that when I find it later I know not to worry about it.
  12. canuckican
    canuckican New Member
    75
    Windsor, Ontario, Canada
    I agree 100% with FlyingPrius: I've got the gap as well and that is about the only thing I looked at in my new car and thought, "Huh! A little shoddy for a Prius..." I'm just surprised they put it together like this.
  13. CHART
    CHART Member
    184
    Mount Airy Maryland, USA
    Whew...its not just me
    I am soooo glad that others have this. I was starting to wonder if mine had cracked. I went out to my car in the garage and even knowing where it was, I couldn't see the split. I took 2 pictures with flash. The 1st picture is from just forward of the steering wheel. The 2nd photo is right on top of the crack.
  14. InTheWASide
    252
    Everett, WA
    Hmmm... Can't say I've ever noticed that before. I'll have to go down and see if my baby has a crack problem...
    Intervention starts at home ;)
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I'm pretty sure but everyone has a crack. :oops: I'm sorry but it was a great straight line. :lol:
