Multi USB Port? Does it work
Discussion in 'Prius c Audio and Electronics' started by Sandman1999, Aug 14, 2013.
  1. Sandman1999
    Sandman1999 New Member
    Los Angeles, California
    Has anyone tried plugging a multiple USB port into the single USB port? Does it work? For example a plugging a USB drive and an IPod? Thanks!!
  2. Zephyr7
    Zephyr7 Member
    301
    28
    it is not stated on the manual, u could certainly try. let us know if it works.
    only 3 things could happen.
    - nothing happen
    - works!
    - reset radio ( don't think u can report this)
    if you use unpowered multi port usb it may not charge ipod and may not work right, u need a powered port. more wires in the car.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    You would need to get a powered USB hub and plug the power adapter into the cigarette lighter. The USB port on the car barely has enough juice to charge your cell phone.
  4. col127
    col127 Member
    345
    Illinois
    Yep - I just did it this weekend. I have a 4port USB 2.0 hub (not powered) that I plugged into it. Had a USB stick & my iPhone plugged to it at the same time and it worked fine. However, the system couldn't read both my USB stick and the iPhone at the same time :p
  5. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    using a multi usb port in the radio usb is just dumb. the radio wont be able to read both the devices, maybe not even one. what i did was just buy a dual usb micro car charger. i can charge my phone and ipad with it while my ipod is playing in the radio.
