Multiple beeping when trying to open driver door
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by apostasy10, Aug 31, 2010.
  1. apostasy10
    apostasy10 Junior Member
    22
    Whenever I enter my prius the car is locked and the alarm is set, and I will grab the handle to unlock and deactivate the alarm. However, every couple weeks I'll grab the handle and it will beep like it's de-activating the car but will beep anywhere from 6 to an indefinitely number of times and won't unlock my door (it unlocks all the others). Anyone ever experience this? Any know if this is a known problem?
    Thanks in advance
    Ben
  2. lonewolf69
    lonewolf69 New Member
    84
    Jericho, NY
    Hi Ben,
    carwash or rain water will get in the way of the sensor and will give false readings (not always but it did happen to me once)... I don't know if this is your issue, but it definately sounds like a SENSOR issue with the SKS, especially if dry.
    Good Luck and keep us posted!
  3. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    If it's an aftermarket alarm system (even if dealer-installed), I'll bet dollars to doughnuts the problem lies there.
  4. apostasy10
    22
    OK - thanks guys. I don't have an after-market alarm--it's just the standard one that came with my '04 Prius. A sensor issue sounds about right because it seems to explain the repeated beeping and it's failure to unlock that specific door. I guess it's something I'll have to take it to the dealer for.
    Thanks again,
    Ben
  5. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    Something that happened to me was that I keep my key in my pocket. And the same thing happened. What I believe happened was that the "lock" button on the key was hitting against something in my pocket, so it kept beeping and locking the door. I just took the key out of my pocket and it worked just fine.
    Dumb Mike
  6. apostasy10
    22
    lol - Yikes that may also be what's happening. I'll watch for that as well next time it happens.
