Multiple misfires after injector repair
Discussion in 'Gen 2 Prius Main Forum' started by Brenscars, Jun 1, 2020.
  1. Brenscars
    Brenscars New Member
    North Carolina
    Recently did a gas engine swap on an '08 Gen 2. Initially had horrible misfires after swap. Cleaned throttle body and put fresh gas in it and no problems for the last month. Until one of the top seals on one of the recently replaced injectors failed and caused a small fuel leak. Today I fixed the leak and now have multiple misfires again as well as a trouble code for the mass air flow sensor and lean bank one too.. I have another '08 that I was able to swap out a MAF from and concluded that is NOT the problem. Any help is very much appreciated.
    moha777 likes this.
  2. ChapmanF
    15,588
    Could be unmetered air (air leaking in somewhere downstream of the airflow sensor). A smoke test might help find the leak.
    What are the codes you have exactly?
  3. moha777
    moha777 Junior Member
    GB
    Hi I have misfire in my 08 prius what code u getting
  4. Brenscars
    North Carolina
    Got codes PO300, PO301,P0302, PO303, P0171. Problem was resolved by removing #4 injector and cleaning where the bottom seal meets the cylinder head. Thank you.
  5. Brenscars
    North Carolina
    Got codes PO300, PO301, P0302, PO303, P0171. I just replaced all the ignition coils and spark plugs also before this happened.
  6. Brenscars
    North Carolina
  7. Brenscars
    North Carolina
    One thing I noticed on the bottom of the airbox where it meets the throttle body, on the clamp that seals it up there is a notch in the clamp and a small piece on the rubber airbox connection that fits into that notch. If you don't have that lined up correctly it won't seal and you may get a MAF trouble code and a misfire from it due to the sensor sucking to much air and essentially a vacuum leak.
