Mushy brake pedal.
Discussion in 'Prius c Technical Discussion' started by alexeft, Mar 27, 2018.
  1. alexeft
    alexeft Member
    142
    24
    Greece
    Hi all,
    Just got a yaris hybrid (should be the same as the prius c).
    The brake pedal seems quite soft and allows me to push it down to the floor. Should this be the case? What is it like in your prius c? Is the pedal firm?
    Please note that the car brakes very well and no warning lights are on.
    Thanks for your answers.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It sounds to me like either there is air in the brake system or the fluid is low. Or both. In any car, it should not be mushy.
    ztanos likes this.
  3. zeuloa
    zeuloa Member
    30
    26
    Managua, Nicaragua
    2014 Prius c
    Mine doesn’t feel extremely firm but it doesn’t seem to be mushy as you describe yours.
    Do you know when brake fluid was replaced last? It’s required every 2 years according to my manual.
    iPhone ?
  4. alexeft
    alexeft Member
    142
    24
    Greece
    Just went to the local dealership and tested a new one. It certainly is firmer, though not as firm as traditional cars.
    Had a talk with the service and they said that it is ok, especially since there are no warning lights. But i will replace the fluid anyway and bleed the brakes along the way.
    Thank people.
    PS: android 7
    jerrymildred likes this.
  5. Mendel Leisk
    41,860
    My guess would be a previous brake fluid replacement that allowed some air into the system. Video #18 here by @NutzAboutBolts :
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    outlines a brake fluid replacement on regular 3rd gen Prius. I'm not sure how applicable that'd be to your car, but hopefully would help. Try the "invalid mode" procedure for example, see if it works on your vehicle. A few comments on the video:
    1. Motorized vacuum source, while handy, is not mandatory. I managed with just a syringe for basting fluid out of the reservoir, and for everything else just relied on someone pushing the brake pedal. I used a tube with a proper brake bolt nipple connector, and a large plastic jar with lid (hole drilled in lid for the tube). Cheap and simple.
    2. At least according to the Repair Manual for 3rd gen Prius, the recommended order was Front/Right, Front/Left, Rear/Left, and Rear/Right.
    3. I purchased and used two pints of Toyota DOT3 fluid, and that worked well. Per the video, I started out by basting out and refilling the reservoir with clean fluid, then did maybe 100~150 cc on each of the fronts, and the remainder on the rears. I checked the level in reservoir at the beginning, and set it at the same level at the end, holding a little of the new brake fluid in reserve, monitored the level over the next few days. Eventually I just recycled that reserve with the used stuff, since it doesn't store well.
    The video is very well done, with split-screen showing how to open/close the bleed bolt, in conjunction with the pressing of the brake pedal, in particular with the front brakes. Following this, I think you'll expel air in the lines, end up with firmer brake. If not, maybe you have air back at the master cylinder, and then it might be time to get a Toyota service department involved.
